Author Topic: using Multiplying DAC to generate variable height pulses  (Read 2999 times)
Offline eliocorTopic starter
    • rhodiatoce
« on: September 02, 2012, 11:52:17 pm »
I need to generate rectangular pulses with width between 1 and 10us: their output peak voltage can range from +5V to -5v in (at least) 5 mV steps.
The original pulse (generated by a PWM microprocessor pin) have a pk-pk output voltage of 5V:
What I need is a variable attenuator with at least 10 bits of resolution (better 12 or 14 for linearity reasons).
I was thinking to use a Multiplying DAC like the AD5446 (14bit) set in 4 quadrant configuration: 13 bit for attenuation and one for sign [see Bipolar Operation, pag. 16].
This device is reasonably cheap for my requirements and its reference bandwidth is 12MHz.
The output results could be summoned in the following two pictures:
output set to 2.7V from the original 0-5V pulse
output set to -3.3V from the original 0-5V pulse
The output pk-pk voltage need to be changed not more than once per second.
Based on your experience, do you think my approach can be worthful?
Have you different suggestions/solutions on how to solve my needs?
« Last Edit: September 02, 2012, 11:57:22 pm by eliocor »
Online jahonen
Re: using Multiplying DAC to generate variable height pulses
« Reply #1 on: September 03, 2012, 02:13:14 pm »
I can't say if it is any simpler, but maybe another option would be a normal DAC (connected to have a bipolar output) and an analog MUX to select either zero voltage or the DAC output according to the MCU PWM output?
Regards,
Janne
    • rhodiatoce
« Reply #2 on: September 03, 2012, 02:28:49 pm »
It seems interesting: I have to look at the commutation speed of the analog switch, but it should work.
Thanks for the suggestion.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: September 03, 2012, 02:33:29 pm »
Jahonen is right.
Sending this kind of signal through a multiplying dac will be trouble... The bamdwidth limitation of the dac will heavily distort the edges...
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #4 on: September 03, 2012, 07:02:40 pm »
The AD5444 has a 3dB bandwidth of 12MHz, I can't see 1uS pulses being a huge problem.
    • rhodiatoce
« Reply #5 on: September 03, 2012, 07:36:04 pm »
Yes, 12MHz bandwidth can be enough, but I like the suggestion of using a "standard" DAC:
my project will be open sourced, so I have to care about the possibilities of using different hardware.
A "standard" DAC will be easier to get than a Multiplying DAC.
In the next days I hope to get some time to test this configuration and see if it can be better than my initial thoughts:
my request for comments was for identifying the cheapest and safest way to generate those pulses.
Thanks in advance for all of your welcome comments!!!
