Author Topic: Recommendation for pluggable connector  (Read 702 times)
Offline mickeyscemeTopic starter
« on: February 13, 2019, 05:39:09 pm »
Hi guys,
My name is Mike, I am currently working as a Mechanical Design Engineer in the lighting industry. The project I am working on involves electrical part in it, and selection of drivers and connectors amongst other tasks.
I am looking for a 2 pole/circuit connector that will look like this one wago 890
I am looking for something more compact with push in wire capabilities, ideally panel mount on one side and plug on the other. If possible, with a latch for locking.
I also checked for AVX, BINDER, PHOENIX, TE and MOLEX vendors. All connectors require assembly of pins and wires to complete the harness assembly, I am looking for push in or some other mechanical quick assembly that does not require additional processes.
Any help is very much appreciated.
Best regards,
Mike
Offline TimNJ
Re: Recommendation for pluggable connector
« Reply #1 on: February 13, 2019, 09:44:52 pm »
So you want to push the wire into a male plug, and then plug that into a female header on the product?
Do you need to use a plug-able connector? How about plugging bare wire directly into the product with spring-loaded contacts? Not allowed?
Offline ajb
« Reply #2 on: February 13, 2019, 09:54:15 pm »
What are your current/voltage requirements?
