a friend of mine got a few rackmount 12V SPAFFIV-03G powersupplies and asked me for help how to turn them on. I've found description of PSU output connector in
https://belfuse.com/resources/datasheets/powersolutions/ds-bps-fnd300-series.pdf .
Unfortunately, there is no PS_ON pin.
Do you know what standard this power supply is compliant with and how to turn in on ?
PIN SIGNAL NAME DESCRIPTION
1-3, 13-15 V1 RTN V1 Output Return
4-6, 16-18 V1 V1 Output
7 - Not Used
8 - Not Used
9 PF Power Fail
10 I2C Voltage Input/Output
11 SDA Serial Data Line
12 SCL Serial Clock Line
19 - Not Used
20 - Not Used
21 LSB Address Input Line
22 RSD Power Supply Remote Shut Down
23 PS_PRSNT_L Power Supply Present signal
24 Fan Fail Fan Fail signal
