Author Topic: Reconstructing schematic from two layer PCB  (Read 1791 times)
Offline bigmacTopic starter
« on: January 03, 2020, 10:36:35 am »
So... i've got myself into a bit of a project.
Quick story.
I bought an electric car, a Kewet El-Jet 4 from 1995. Not working. Turned out it had the wrong type of computer installed.
So.. I sourced another El-Jet 4 in order to get the computer.
My plan is to copy the computer.
so i ripped the computer out, photographed it, documented all of the parts, desoldered, scanned, retraced in sprint layout....
but now i'm kinda stuck. I can export gerbers from Sprint layout, but to where? What would be the best route here? (pun intended) thank you
Offline mc172
Re: Reconstructing schematic from two layer PCB
« Reply #1 on: January 03, 2020, 10:57:18 am »
Why do you need the schematic in order to make a copy? If you've copied the layout and know all of the component values, that's all you need.
Offline Rerouter
« Reply #2 on: January 03, 2020, 11:02:21 am »
kicad can import the gerbers and allow you to edit them, and I suspect rebuild into a schematic + project, I just have not used it in this manner before,
Offline digsys
    • DIGSYS
« Reply #3 on: January 03, 2020, 11:54:58 am »
If you have all the board details, why not source a spare board or two off ebay / alibaba / aliexpress etc etc
I've found heaps of rare boards for various project I do, rarely failed to find one. Or do you intend to mass produce them?
Offline mikerj
« Reply #4 on: January 03, 2020, 12:43:21 pm »
Easy-PC can apparently do this, though it's a pretty expensive licence for a hobbyist.
If he's also reverse engineering the firmware then a schematic is going to be pretty essential to understand the operation of the board and debug it.
« Last Edit: January 03, 2020, 12:46:13 pm by mikerj »
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #5 on: January 03, 2020, 12:51:18 pm »
Problem is, it is not a two layer, but a four layer PCB, or you have a lot of traces missing.
Dead giveaway is the JP7 at the bottom, which is a RS232 connector, missing a GND connection from pin 5, that likely is going to an internal GND layer.
The following users thanked this post: mikerj
Offline mikerj
« Reply #6 on: January 03, 2020, 01:07:19 pm »
Agreed, most of the bypass caps show only one pin connected, and C16 has no pins connected.  A large number of unconnected IC pins as well.
Offline tooki
« Reply #7 on: January 03, 2020, 01:13:47 pm »
Besides, are the ROMs even copyable? If it uses a CPU or MPU with mask ROM or read-only EPROM, then even if you copy the board, it’d be useless.
Offline Prehistoricman
« Reply #8 on: January 03, 2020, 02:43:04 pm »
The current project I'm working on is exactly doing that. In fact, it's of similar vintage so maybe it's the same CPU? :o
"Is it possible to learn this power ROM?"
"Not from a Jedi mask"
« Reply #9 on: January 03, 2020, 03:39:46 pm »
Ground planes on both sides. Removed for clarity. Good spotting though!
« Reply #10 on: January 03, 2020, 03:46:11 pm »
Latest gerbers uploaded. If anyone could give me a hint on how to proceed id be very thankful thanks
Offline ebclr
« Reply #11 on: January 03, 2020, 10:03:05 pm »
If you are looking for a paid service those guys may help you
https://www.pcbic-reverse.com
