Hello,
I'm need a buck converter that will convert 6.2-8.4V from 2S LiPo pack to 5V at 0-5A. Key parameters are low complexity, low cost and good load regulation. I have a few options from Texas and Linear, but they are either expensive(Linear), hard to get in my country (new TI chips) or both.
My first shot was LM3475, because it is small and cheap and not actually current limited because of external PMOS. The downside is that it is a hysteretic mode controller, which means that its frequency varies greatly with load and so does the required inductance value.
Second shot is LTC1773 but it's very expensive (~4€) and only available from Farnell.
Can you recommend any particular chip?
