You could also use any bit of little logic with complementary outputs: a flip flop, a differential bus driver, and so on.
If you're looking to use a better reference voltage than simply taking whatever a CMOS gate tied to a digital logic supply rail will give you then something like a 74x4053 analog switch with two switches wired in complementary fashion would do the trick. (If the non-linearity of the switching element RDSon with voltage bothers you it can be largely eliminated by placing it at an op amp virtual earth summing point.)
