Author Topic: Reducing Current Consumption in the PCB  (Read 774 times)
Offline A.ErsozTopic starter
« on: March 21, 2019, 04:58:33 pm »
I tested my custom design PCB with four SPST analog switches and four opamps and total current consumption seems on power supply around 80mA. Now, I added 28 analog switches and 28 opamps on PCB. Now, the current level is 700mA. The linear voltage regulator is heating too much. So, why the problem can be occur? Output of linear regulator is 150mA.
Thanks
Offline TimNJ
Re: Reducing Current Consumption in the PCB
« Reply #1 on: March 21, 2019, 05:33:56 pm »
Are you asking why your linear regulator is getting too hot? It seems you've already kind of answered that!
Offline Kleinstein
« Reply #2 on: March 21, 2019, 05:46:01 pm »
Usually the CMOS SPDT switches use essentially no current (e.g. < 100 µA). For OPs using 80 mA is quite a lot - there must be quite some load to them.
With 7 times the circuit one can expect 7 times the power supply: 7 times 80 mA would be 560 mA so already quite a bit. 700 mA is little more, but not that much.
Chance are the circuit is bad from the beginning - either a poor plan, a wrong inserted part or a broken one.
So back to the simpler 4 OP circuit and bring the current down to some 10-20 mA or less.
The following users thanked this post: A.Ersoz
Offline iMo
  • Country: va
« Reply #3 on: March 21, 2019, 06:18:17 pm »
4kg of apples cost $80.
How much (4+28)kg of apples cost?
32/4*80=$640.
You can hardly get 640mA out of a 150mA voltage regulator.
The temperature of a LINEAR voltage regulator package could be calculated as follows:
T = Tamb + (Vinput-Voutput)*Ioutput*thermal_resistance_of_the_package
Example:
Tamb = 25degC
Vinput=15V
Voutput=12V
Ioutput=150mA
thermal_resistance_of_the_package=60degC/Watt
T=25C+(15V-12V)*0.15A*60C/W=25C+27C=52C
The thermal resistance of the package you will find in the datasheet, it depends on the copper area beneath the smd package, or the type of a heatsink attached.
« Last Edit: March 21, 2019, 06:48:15 pm by imo »
