Author Topic: Reed switch coil design  (Read 879 times)
Offline edbaTopic starter
« on: April 28, 2020, 06:39:31 pm »
Hi
I have a reed switch (STANDEXMEDER MK23-85-C-2) and I want to wind a coil onto the glass body to be able to operate as a reed relay. The reed switch glass body winding area is 15mm appx x 2.75mm dia winding area. The contacts are specified to close between 15-20AT. I know I had a book years ago explaining how you could wind a coil on the body to operate it. Ideally I would want to operate the reed relay with a 20mA current at 5V. Does anyone know about the calculations involved in working out the number of turns required?
Edba
Offline langwadt
Re: Reed switch coil design
« Reply #1 on: April 28, 2020, 08:25:08 pm »
something along these lines 20AT/20mA = 1000 turns, adjust wire size until you get 5V/20mA  = 250 Ohm
« Reply #2 on: May 01, 2020, 07:59:29 pm »
Hi
Thamks for your reply. I would like to do a bit more reading about this, do you know of a good tutorial on the web? Also do you know of the formula for calculating the length of wire vs no. of turns for thickness of wire. I have done some coil design but not for about 25 years!
Edba
