Hello,
I have thought about building a bench power supply, as I have gone a long time without one. I wanted it to have both positive and negative 12V rails as well as a variable one, probably using an LM317. I wanted it to be as oscilloscope safe as possible, but i wasn't sure what needs to be done in terms of grounding. Is it possible to completely isolate the supply from ground while still having both positive and negative rails?
Thanks
