I'd stay away from direct mains sourced voltages due to the inherent danger and the pain of wiring for AC.
Agreed!
Mains AC scares me: a) because it can kill me fairly easily and b) because it's AC which I rarely play with.
I have a MC34063 design producing 180V quite happily
I've settled for the MC34063 as the DC/DC controller: still to work out the support circuitry for it - that side of things can wait until later though
they are still buyable. not sure for how much longer. probably a few years, at least (guessing).
Ah, and there's the rub! I'm wanting to use (as much as possible) off-the-shelf parts that are still in production or are easily replaceable :p Which is a pity, because some of these old driver chips would have done the business! Though some of them are a more than a
little costly anyway (at least to buy in the UK (at least as far as I've seen!))
And that brings us to today...
I tried to order the bulk of my parts only to discover that the HV5622 I had originally settled on as the nixie driver have a minimum purchase order of 96 from Microchip Direct: and I don't have a spare £400; unavailable from uk.farnell; and I couldn't be bothered transferringmy entire order into digikey. Actually, importing it probably wouldn't be too hard, but I can't be bothered figuring it out.
Great! Now I need another driver solution (I thought I had nailed it with the HV5622 and it's family of chips! I mean, I
could get them off ebay, but most looked like they were going to take a month to arrive; and some even said they had been used (wait... what!? ew... second hand chips... yuck...))
One option is to return to the idea of driving transistors from a shift register - and by coincidence I already had a latching shift register picked out for running the LED-based fake-nixie tubes; which would almost certainly do the trick (and the latching makes things simple)
Would I be right in saying that tying the common-anode nixie tubes to the collector on the transistors (and having a resistor on the emitter which is tied to ground) work as a solution?
If so, for the sake of an extra layer of protection, would a high-voltage diode between the shift register and the transistor be effective?
Ps - I'm aware hand-soldering 96 transistors is going to be one of the most wonderful ideas I've ever came up with! But it's going to be done as a modular series of boards so I can bring the workload to a manageable level (and easily replace anything that blows up)
