If you want to just throw something together, get a canned crystal oscillator for 10 or 20 MHz and feed it into a series of decade counters to get the frequencies you need. Run the output into a oneshot to get the timing pip.
Or, do it all in software with an Arduino or other small processor. If you do that, you'll probably spend more time on the UI than anything else.
