It's a 1h fast charger, so probably not.
The key to NiCd and NiMH charging is that, as you apply the constant-current charging current, the voltage gradually rises and rises until the battery is full, at which point all subsequent charging current is converted to heat. The increased temperature in turn causes the battery's voltage to drop a bit (negative voltage change, aka -dV)*. So the charging algorithm is to monitor the voltage and keep track of the peak, and once you detect the voltage falling rather than rising, you know you're charged. The issue is that the voltage drop in NiCd is quite pronounced, while in NiMH it's much more subtle. So if you design a charger expecting the generous voltage drop of NiCd, it won't detect the small voltage drop in NiMH. (Or it won't until the NiMH is horribly overcharged.)
*because it's also wise to monitor the temperature with a sensor, chargers usually do both, known as -dV/dT charging. The temperature sensor will detect that the rate at which the temperature rises will jump, from the slow rise during charging, to a rapid rise when full.
