Check out my first attempt at a DIY Home Automation project.
With this small box I could control my tv, led strip, sound system and lights. It would also monitor the inside humidity and temperature as well as get real time data from an external API for the outside humidity and temperature and display them nicely in a graph. I even save all these values to a local database and display those values in a chart based on the date I choose.
Hope you guys like it
