... but some caution needs to be exercised on high current relays. These relays typically have a minimum operating current/voltage that is needed to overcome surface films that can accumulate on the contacts. The contacts have to designed for their robustness when hot switching signals, so this limits the material choices available to the relay manufacturer. If the relay has not been used for a while, or if it has been used for hot switching loads, the contacts at low current/voltage may exhibit variable or even open circuit values.
