Author Topic: Problem in Power integrity analysis on a two layer pcb.  (Read 1514 times)
Offline kumarTopic starter
« on: April 24, 2013, 12:17:41 pm »
I am new to emi/emc. So like to ask whether one can perform power integrity analysis on a two layer pcb ( both are signal layers and no plane). We tried but nothing worked. Can any expert guide me?
Offline AndyC_772
Re: Problem in Power integrity analysis on a two layer pcb.
« Reply #1 on: April 24, 2013, 06:26:24 pm »
Yes, but it'll help to know more about your design. What kinds of circuitry are you using (ie. analogue, RF, digital or power management), how big is the board, how much power does it use, what's the nature of the problem you're seeing?
Without specifics, you might get a lot of generic advice, but little or none of it could be applicable to your actual PCB.
A good start is to post your schematic and some gerbers or PDFs of the board. Can you do that?
