I'm trying to turn my adhoc isolation setup on my test bench into something a bit more convenient. I currently have a an isolation transformer, which has a variac plugged into it. Sometimes I put a dim bulb in series with it, and sometimes I don't want it isolated so I have to move the variac plug to the non-isolated outlet.
So I've mounted a switch box with 2 switches, one which bypasses the dim bulb, and one to switch between isolated and non-isolated. (I also have 2 banana jacks on there which need to be shunted for power to reach the DUT, so I can insert an e-stop for when sparks fly.
The plan for switching between isolated and non-isolated is currently to use a DPDT relay to switch the hot and neutral wires feeding the outlet the variac will be plugged into. However, in the middle of putting this together I started wondering if there is a more seamless way to handle this -- something that won't cause power to the DUT to be interrupted when switched. I'm assuming shorting the primary to the secondary of the isolation transformer will cause problems since the transformer is not ideal, and the voltages might not be 100% equal, there might be some phase shift, etc.
What could work for seamless switching the isolation of the DUT?
