Look at the drawings to confirm there's enough space inside the enclosure for the PCB.
You're quire lucky you have a choice. Most of the time I have to design the PCB to fit the enclosure. This can make laying it out more challenging, especially when I have to take account or the height of the components and some areas of the PCB can't have any components or tracks on the outer layers, as it will be mounted to a metal surface.
