Author Topic: Reliable Low Cost Method to Convert 24VAC to 24VDC  (Read 2645 times)
Offline GeorgeIoakTopic starter
« on: April 17, 2019, 05:44:08 pm »
I'm working on a redesign of a HVAC controller board that was designed maybe 20 years ago. Due to cost (and potentially reliability) I'd like to use a LDO and the ST Micro L7824CDT-TR is a nice low cost fixed 24VDC output.
  • To convert the 24VAC to DC I plan on using a bridge rectifier with smoothing capacitor so I'm expecting about 34VDC (24 * sqrt(2) = 34V) going into the LDO.
  • The 24VDC rail will be powering a bank of relays being driven by a ULN2803 and a few LEDs for status. Only 3 relays will be powered at the same time and I'm estimating that to draw ~15mA each
  • Adding current up we're looking at ~50mA for the relays and less than that for the LEDs but round up to 100mA
  • After the LDO with be another LDO for a 3.3V rail powering a STM32 and some optoisolators on the input. Best guess right now might be another 100mA
So I'm looking at the power dissipation for the LDO to be at least 1W (10V * 100mA) which might not be too bad for a D2PAK but ambient in a home's attic can get fairly hot and I'm looking for long term reliability. Switching to a TO-220 with heat sink would solve the "problem" but that drives up cost. I'm thinking of perhaps dropping the input voltage to LDO with maybe a diode. I've seen designs which also use a TVS on the input so perhaps one of those could be used which is rated at 28V?
I haven't used a TVS before so perhaps it's not the right part for what I'm trying to achieve.
I hoping that someone here has done industrial designs and can help me out with ideas.
Part II of my question is on the protection across the relays (which drive 24VAC motors which pull ~385mA). The reference board I have used a Panasonic ERZV07D560 which is a 56V Varistor but in a TH package. I'm looking for a protection device to place across the relays that is a SMD part. I'm not so sure on how to determine the appropriate specifications to look for.
Thanks in Advance!
Offline TimNJ
Re: Reliable Low Cost Method to Convert 24VAC to 24VDC
« Reply #1 on: April 17, 2019, 08:57:06 pm »
You don't want to use a TVS in parallel with the input. A TVS (or a regular zener) used as a clamp needs to "work against" the input impedance of the source. Think about it: If the source resistance is 0, then no matter how much current the TVS "pulls" it cannot change the voltage across itself. In general, I wouldn't use a TVS in parallel for continuous operation. The TVS will have to pull a lot of current to maintain 28V (for example) across itself, by dropping voltage across the series input resistance.
On the other hand, using a TVS in series may work okay. (A normal zener might have a more tightly controlled Zener knee voltage). I suppose you could use something like a 4.3V or 5.6V zener. Maybe an SMA size.
Have you experimented with PCB copper heatsinking? Double sided board with thermal vias?
The following users thanked this post: vad
« Reply #2 on: April 17, 2019, 09:16:23 pm »
I was thinking of using a diode to get a drop before the input to the LDO. The RS1M has a 1.3V Vf at 1A. I was thinking of a Zener as well but I'm not sure why you stated a 4.3V or 5.6V. Wouldn't I want something more like a 28V that's placed right before the LDO. The Zener would then bring the ~34VDC from the diode bridge down to 28V and the LDO would only have to drop 28V down to 24V.
I saw something like this in 1 design where they took 1 leg of the 24VAC, ran that through a fuse wih a 56V Varistor in parallel across the fuse. After that was a TVS before the input to the regulator. Something like this:
Offline ajb
« Reply #3 on: April 17, 2019, 09:34:53 pm »
TVS diodes are designed to handle brief surges (hence the Transient in the name), so while they boast high peak power ratings, the acceptable continuous power dissipation is going to be much much lower (and you might not even see a rating for it in the datasheet).  This is related to the fact that they tend to come in packages with fairly poor junction to ambient thermal resistance.  A better bet is probably to use a second DPAK LDO in series to spread out the power dissipation.  You could also use split the load into two separate +24VDC rails with their own LDOs, which would accomplish the same thing, but it may not be realistic depending on your load characteristics.
Alternatively, how close to 24VDC do you actually need your relay supply to be?  Relays tend to tolerate a fairly wide range of coil voltages, so even if you can't go unregulated, you may be able to bump up the rail to 28V or something--obviously the coil current will increase according to its DC resistance, but this should still result in a net reduction in LDO dissipation (coil current goes up by 17%, but LDO series voltage drops by 40%).  You could also implement peak-and-hold driving by simply PWMing the coil after it pulls in to reduce the steady state current consumption, but that's probably not necessary if the coil is only pulling 15mA.
Offline TimNJ
« Reply #4 on: April 17, 2019, 09:58:09 pm »
Typically, a TVS diode is used to clamp a momentary spike. All voltage sources have some series output resistance. Think Thevenin model. A TVS can't work unless there is ~something~ in between the TVS and the source. That something is a resistor. If the TVS and source were connected directly in parallel (perfect conductor), then how could the TVS do any clamping? The voltage across the TVS would have to be exactly the voltage of the source.
Offline edavid
« Reply #5 on: April 17, 2019, 10:33:10 pm »
The 7824 is not an LDO!  It has a 2.5V dropout voltage.
« Reply #6 on: April 17, 2019, 10:40:13 pm »
OK, good points, thanks.
Yes, I'm planning on using an American Zettler AZ943 because they are lower cost than the Omrons and I've had no issues with them in other applications. The coils are rated at between 18V as the must turn on voltage and a max of 31.2V. I guess I could switch to an adjustable LDO and sacrifice having to place the 2 feedback resistors. Remember when I said low cost, well I even have to think about how many placements and how many unique part numbers.
Splitting the load probably wouldn't be a good option as you don't know which relays could be activated so you could end up with everything on 1 LDO and the other LDO somewhat idle. I do like your outside the box thinking though!
So I guess if I added the diode to drop about 1V before the LDO and then set the LDO to output to 28V that could be a good compromise. I definitely would add a large pad under the part and also stitch to the bottom layer. I even thought about exposing the area under the LDO on the bottom side of the board and when the relays are wave soldered I'd get some solder on the bottom of the board which would slightly help and act as a poor mans heat sink.
« Reply #7 on: April 17, 2019, 10:43:10 pm »
Yeah, my bad, I shouldn't have called that part a LDO but I've had linear regulators on my mind and just wrote that. In my case the larger drop out doesn't matter since I've got such a relatively high input voltage that needs to drop anyway. A true LDO and the 7824 will still dissipate the same amount of heat though, right?
Offline edavid
« Reply #8 on: April 17, 2019, 11:02:40 pm »
Right.
« Reply #9 on: April 17, 2019, 11:16:38 pm »
OK, so unless someone else comes along with a better idea I think it's the diode before the linear regulator and then set the regulator to output 28V instead of 24V.
Now, I'd like some advice on the relay protection. I've seen the Panasonic ERZV07D560 Varistor used and I need to find something in a SMD package as a replacement.
We know that we've got a 24VAC motor that is driven by the relay and that the motor draws ~385mA. The transformers used to power these systems are probably not the tightest in specs so I would assume the 24VAC could go up to ~28VAC.
Offline james_s
« Reply #10 on: April 18, 2019, 02:20:29 am »
Why do you want a diode before the regulator? The dissipation will be exactly the same, you'll just have more parts getting hot. The *only* time you need a LDO is when the input voltage is too close to the desired output voltage to cover the dropout voltage of the regulator. Any linear regulator will dissipate exactly the same amount of heat when dropping the same voltage to deliver the same current.
I rarely use linear regulators anymore, small switching regulators are cheap and trivially easy to use these days. So long as you use reasonable quality capacitors they will be very reliable.
Offline TimNJ
« Reply #11 on: April 18, 2019, 02:36:35 am »
Have you looked at any papers on D2PAK dissipation vs ambient vs copper area?
https://www.st.com/resource/en/application_note/cd00004438.pdf
By the looks of it, 2W seems like a more reasonable upper limit for dissipation on a D2PAK, if the ambient is quite high, 60C for example.
« Reply #12 on: April 18, 2019, 04:13:01 pm »
My thought of placing the diode before the regulator is exactly as you stated, to spread the heat between 2 devices rather than having the regulator dissipate all of the heat. The lower the temperature of parts the better the chances of the part not dying too soon.
I've done many switching regulator designs so that doesn't scare me off but the total cost of a switcher (counting both parts and assembly) is going to be much higher. When you're building thousands of units $0.50 (or more) can add up quickly.
@TimNJ, thanks for that app note, I hadn't seen that one and it looks useful. I think anyone's attic could get up to 60C so that's what I have to design for
