I'll give you the backstory.
Monitor came to me with the complaint of a "burning smell". Well the plastic protector covering the neck had melted and dripped searing hot plastic onto the chassis destroying several wires. The back of the neck board was completely and totally black, covered in soot, as well as inside the neck board socket that fits onto the tube.
I tested the tube, and it tested fine with my B&K 467.
I repaired the wiring, cleaned the neck board, replaced the socket, and flyback and turned it on to test.
It worked, but the B+ was 133, and I thought it was supposed to be in the 120s.
I re-capped the entire power supply section (you see in the schematic above) turned it on and NOTHING.
When looking at the board, I accidentally put in C610 (I think could have been C609) backwards when I tested it.
Re-installed the Cap, and also changed out C909. Still 0 volts on the B+ test point (cathode of D605).
Changed the VR (this is a highly counterfeited part, so hard to get) and same issue, 0 on the B+.
Ran wires from the filter cap (c606) and the bridge (D601) both were putting out 170volts.
Tested the VR and only get 170volts on pin 1, nothing on 9 which I thought was the output.
I originally thought it was the VR, they're about $10 a piece so I thought I'd test them and they are not shorted, but not putting out the voltage. So I thought I'd learn more about the VR and the pinout, and you see the datasheets I do. No other references on the net or the arcade forums about this, so it seems like I'm on my own.
It seems like the VR is getting an "ok" supply voltage, but not outputting anything. I am more familar with the VRs that do everything themselves, and this one has quite the schematic behind it, as well as about 11 components connected to the other pins for whatever reason.
