You'll have to measure the current drawn from the battery, and the minimum voltage that the camera needs, and work out if the supercapacitor can remain above that voltage for long enough at that current. 0.22F won't provide much current for a day though.
You'll also want to check that the charging circuit is compatible. If it's a simple 3.3V source connected to the battery through a resistor then it will be fine.
