I need to recap an old PSU, can somebody recommend a brand/series of capaciter and best place to buy from. I found the values I needed on RS but, not cheap and some are just general purpose series. I've read that FM, FC, FR series are good ? Values are
100uF 50v
47uF 50v
470uF 35v
330uF 50v
1000uF 35v
4000uF 15v (sprague can neg)
An additional problem is that a lot of the newer capacitors for those values are a quite a bit smaller and the lead pitch is different so they don't fit the holes in the board. I'm guessing I can upsize capacitance/voltage rating a bit to get the right size.
