Author Topic: Replacement for TIP36 transistor  (Read 1130 times)
Offline IconicPCBTopic starter
« on: April 09, 2019, 10:32:41 pm »
The replacement issue is not too difficult to resolve however I am looking for a TIP36 like transistor with a lower beta than tip36.
In fact I am presently using  TIP36 however I am looking for similarly specced transistor with a beta of 15 to 20 at collector current of 10 amps.
BD250 seems like a suitable candidate unfortunately it is obsolete.
EDIT: obsolete according to some suppliers , element14 claims 600 odd pieces world wide.
Element14 offers a Multicomp device which is different to some older sources... back to square one.
« Last Edit: April 10, 2019, 12:00:35 am by IconicPCB »
Offline Cliff Matthews
    • General Repair and Support
Re: Replacement for TIP36 transistor
« Reply #1 on: April 10, 2019, 12:48:21 am »
Alltransistors.com is helpful. Search on TIP36, > 'find substitute', > search again results (after changing parameters desired).
Here is similar devices, (without limiting results to a TO218 case) scroll down - there's a big list. - Hope that helps!
Offline radix
  • Country: si
« Reply #2 on: April 10, 2019, 06:52:01 pm »
Why wouldn't you just put a resistor across the BE junction?
Online oPossum
« Reply #3 on: April 10, 2019, 08:02:46 pm »
« Reply #4 on: April 10, 2019, 08:19:18 pm »
That is wha I have done. Effectively a 2.5 ohm resistor did the trick.
