100 Hz flicker is very, very obvious to me, it's something that really jumped out when I visited England. Part of that is the lower frequency and part of that is probably that I'm used to 120 Hz flicker, it got less noticeable after a day or two but motors and transformers still all sounded weird to me. My friend from there is over here somewhat regularly for business and has said the same thing about the motors and transformers here sounding weird.
I can see flicker at much higher frequencies than that though, 300-400 Hz PWM backlight flicker gives me a headache and I can see it in my peripheral vision, especially if I'm tired. The 1 kHz flicker of Philips Hue lamps is visible any time I move my head or eyes, that took some getting used to at first, now I can mostly tune it out. The PWM flicker of many car tail lights is very visible to me too, again largely down to motion. When people say that the human eye cannot perceive flicker above x frequency they are ignoring the fact that a person is rarely sitting still just staring into a light source. The moment you move your eyeballs to look at something you turn a flickering light into a dotted line and that strobe effect is readily visible well into the kHz range.
