Author Topic: Custom Milled and Turned Hot Air Nozzels Solder Tip's?  (Read 1989 times)
Offline KG7AMVTopic starter
  • Rhine_Labs
    • My Personal Blog
« on: November 23, 2014, 01:24:32 am »
I was thinking about this from past experience most the nozzles for hot air machines are rather cheap? I do not have the funds to have a Metcal, Pace or JBC laying arround not to tool them up!
So, I was thinking maybe I should make my own I have the Equipment to do it!
For the hot air nozzles I was thinking of using good quality stainless or ?. I am Not sure about Soldering Tips but it would doable if I can source proper materials and tech spec's!
My milling Machine small but does every thing I have needed it to do!
Building a CNC Lathe should be complete in a week or so.
Offline zapta
Re: Custom Milled and Turned Hot Air Nozzels Solder Tip's?
« Reply #1 on: November 23, 2014, 01:48:36 am »
What is the problem with the cheap nozzles? Don't they work just as good? (That's what I am using and never had a problem)
  • Rhine_Labs
    • My Personal Blog
« Reply #2 on: November 23, 2014, 02:07:05 am »
I just want an excuse to make something!
Offline PaulAm
« Reply #3 on: November 23, 2014, 02:13:00 am »
You clearly need some projects for those machines.  I don't see a single chip anywhere  ;D
  • Rhine_Labs
    • My Personal Blog
« Reply #4 on: November 23, 2014, 02:17:59 am »
As for the time and effort! It is the satisfaction of making/fixing what you use well I like to fix the things I have when they break and make stuff I want or need!
Here are The Drivers! Feel Better!
« Last Edit: November 23, 2014, 02:21:20 am by KG7AMV »
