You don't need the cap on AREF if you're not using the ADC.
Almost forgot about that cap. I thought to "testfit" it. The next revision may have the possibility to measure the 12/24 volt input (should rename the power port). For now, I will leave the cap in place, even if just for the on board temperature sensor.
Also, are you sure you have the correct value caps on the crystal? 8pf seems low - most common 16 MHz crystals require in the region of 20-30pf.
The datasheet of the crystal specifies a load of 12pF. Now, when reading up on this a few years ago, I got the impression this is the total capacitive load the crystal likes to see. Estimations I found for the pin capacitance of a micro controller are up to 5pF per pin. There are also the pads of the crystal itself and the traces to it. Now, those are estimations, a rule of thumb, not concrete data. I simply decided to go with 8pF. If the requirements of the crystal would be around 20-30pF, the parasitic error would be smaller. The trace and pad capacitance can be estimated pretty well. If anybody knows more about the pin capacitance of an MCU, please let me know. I found oscillator design in general confusing and would like to learn more. In this case, I know that the oscillator works with the values (Had a similar board, the oscillator circuitry and how it was connected to this MCU was pretty much identical).
For now, I will not change the capacitors and hope to get around to do proper measurements with different values. If someone knows of good material to learn more about this specifically, I would appreciate the pointer, it is definitely not a strong area of mine but very important. I was reading that oscillator designs with a too weak or to strong drive are common failure modes, as the quartz ages, it may not be able to start up or breaks down?
It has been a few years. If I remember correctly, in order to measure the drive strength one needs to actually insert a resistor in the path to the crystal. An STM32FXXXX datasheet, I looked at, pointed to a guide on how to do this. I was rather confused back then, never learning much about about crystals, really.
If someone is curios, the crystal is this one:
Manufacturer: TXC CORPORATION
Part Number: AT-16.000MAGE-T
Datasheet:
http://www.txccrystal.com/images/pdf/at-automotive.pdfWould love to hear more thoughts on this, industry practice and, as mentioned, material to read up on about this (advice for books is also welcome).
