This make no sense. MCU reset pin is completely different to what those "paperclip holes" in consumer devices do. They are mainly for resetting to factory settings;
I'm not sure what are these peperclip holes rests for but if the consumer device has any user interface than resetting to factory settings need not any reset pin - user can select the right menu item.
Only if the UI is actually working. Sometimes, bad parameters in flash memory can render a product unusable. In that case a press-and-hold "factory reset" feature is essential.
We need to be clear about the difference: a switch connected to the reset pin of the microcontroller does much the same thing as a power cycle, so is usually pointless. A press-and-hold button to reset any flash-based parameters (ie a factory reset) is a different thing and might be essential.
Finally, if it is not possible to power-cycle the microcontroller due to it being permanently connected to an internal battery, then a switch connected to the reset pin is probably essential.
It is a good design discipline to build a degree of resilience into a product. "Resilience" in this case being the facility for the end user to restore the product to working order if it somehow enters an illegal state.
