Hi All,
I need some advise regarding ADC interface with Microcontroller.
Here, that ADC(Analog to Digital Converter) output is serial LVDS(Low Voltage Differential Signal). How to read the ADC value using microcontroller(MCU)?
I have been come across with that attached block diagram.
In this block diagram, I read analog value using ADC. That ADC output configuration is LVDS(Low Voltage Differential Signal), so that LVDS is converted into TTL level. After that ADC value is passed to Microcontroller. The level shifter is added in between MCU and LVDS-TTL converter, if needed only because of MCU operating logic level.
Is it correct? Please give more suggestion and recommend which MCU, ADC are suitable for that.
Thanks all
