Author Topic: Resistor on a post in CRT monitor?  (Read 401 times)
Offline gmcTopic starter
« on: May 27, 2024, 03:31:21 pm »
I'm busy trying to repair a old 12" CRT from the early 80's - Yes, I'm  aware of the electrical dangers  ;)
One of the components is a 56R resistor which is now reading 100R. Looking at the schematic it's a 56R RN1/4 which from what I can gather is a 0.25W Metal Film Resistor.  Resistor looks a bit worse for wear and has overheated.
That's all good and easily replaceable. One thing that I've noticed is that there are a few resistors around the HV side that have one leg soldered to a post which I've not seen before.
Guessing it's to keep it off the PCB for cooling? But why one leg and why mount it to a post? (Or is the post also some sort of heat sink?)
Was this a standard for the CRT's in the 80's?
Offline johansen
Re: Resistor on a post in CRT monitor?
« Reply #1 on: May 27, 2024, 04:38:31 pm »
Usually 2 posts were used to keep the heat away from the board
Offline jonpaul
« Reply #2 on: May 27, 2024, 04:56:26 pm »
post keeps HV arc to PCB surface eg dust.
Very common.
Use carbon comp resistor rated for the HV
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: gmc
« Reply #3 on: May 27, 2024, 06:08:33 pm »
Thanks for the info. Will source the correct resistor replacement.
Offline inse
« Reply #4 on: May 28, 2024, 03:57:50 am »
You can see the windings, this isn’t a carbon composition resistor but a metal film type.
« Last Edit: May 28, 2024, 04:52:41 am by inse »
Offline CaptDon
  • Country: is
« Reply #5 on: May 28, 2024, 04:31:22 pm »
I absolutely agree that it is metal film!!! Carbon Comp replacement is a huge mistake seeing how the metal film burned up. I would also recommend the flameproof version FP which the original resistor probably was. Looks like the O.E.M. expected a possible failure mode of this part and could be part of the reason for the post mounting.
