Author Topic: Power supply schematic input  (Read 2190 times)
Offline ahnuts72Topic starter
« on: May 06, 2013, 03:30:48 pm »
Was wondering what everyones
take on this supply is.
I want to replace my lm338 supply.
Sent from my Milestone X using Tapatalk 2
Offline penfold
Re: Power supply schematic input
« Reply #1 on: May 06, 2013, 03:51:10 pm »
Looks like it should work pretty well.
The only few things to comment are perhaps:
The lack of compensation on the opamps, but that will depend a lot on the exact amps you end up using and what sort of response you're after
And lack of variable current limit, I'm assuming you considered that but went for the more elegant solution
« Reply #2 on: May 06, 2013, 05:25:02 pm »
Im still looking for one with current limiting that I might try to build.
I would like to have current control
as well.
Im looking at some Power Design
supplies on ebay but I want to build this as a learning experience.
