watch Al braze videos on youtube. They compare rods. Some are shit and some are good. Some rods only meant to make a fat bump on top of a severely damaged aluminum radiator tube.
I highly recommend soldering it with the viscous yellow flux and solder. my luck with brazing it is totally fail.
also get a wooden brush with steel bristles, not plastic, so it does not melt if you try to scrub it while keeping it hot and stuff. seriously at your own risk.
I said this before, when you practice brazing, after you braze, file it down a bit, then pick at it with a strong steel pick. You will see sometimes you have something that looks great but if you jab into it and yank on it, chunks come out.
but if its a 1950's engine casting, its probobly good. people actually thought aluminum was amazing and engines were amazing back then so they used to get it right, now its ubiquitous and low cost IMO. I imagine someone actually did everything right and put effort in it because they thought it was some jetsons space age shit
There was a aluminum bit on top of the washington monument because it used to be the worlds most expensive metal. It was like putting a big diamond on the pyramids back then lol
also the braze is really brittle so I don't recommend it for handles. If anything, I would get some thick shim stock and try to just make a big aluminum solder lap joint under the thing to reinforce it after you cosmetically filled in any gaps with stiff braze.
and if aluminum was easy the navy would not have so many problems with their aluminum boats lol
