Author Topic: LTSpice - varying frequency along time  (Read 4283 times)
Offline atferrariTopic starter
  • Country: ar
« on: February 14, 2015, 07:32:51 pm »
LTSpice simulation.
I could not find a way to implement this:
a) Testing a circuit fed with a fixed amplitude sinusoidal voltage source varying frequency along a certain period. Say, in 2 seconds, between 6KHz to 450 Hz  with 0.5 V amplitude.
b) Later I would like to test the same circuit in the same period at a fixed frequency with a varying amplitude.
c) And last, eventually, mixing both options.
Is such a thing possible? I fear I am out of luck here.
Please note:
I am not trying to do a .tran .ac simulation; my test is in one pass along time and stepping a parameter is not what I need either (well, the way I know to use it, at least...).
Suggestions appreciated.
« Last Edit: February 15, 2015, 07:18:08 pm by atferrari »
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
Offline c4757p
  • adieu
Re: LTSpice - varying frequency along time
« Reply #1 on: February 14, 2015, 07:34:35 pm »
I am not trying to do a .tran simulation; my test is in one pass along time
That's the whole idea of a transient simulation!
AC analysis?
The alternative it to use a behavioral voltage source and put in the equation for the signal you want by hand. I'd go with an AC analysis though.
  • Country: ar
« Reply #2 on: February 14, 2015, 07:52:05 pm »
AC analysis?
I spent some time reading about the behavioral sources but couldn't come to try anything yet. Any link where to go for read some concrete examples?
Agustín Tomás
Offline MrAl
« Reply #3 on: February 14, 2015, 07:53:49 pm »
There is a VCO in the software.  Use a ramp voltage to control it, that gives a frequency sweep unless it has sweep built in.
Offline c4757p
  • adieu
« Reply #4 on: February 14, 2015, 07:56:36 pm »
AC analysis?
It's just a source that takes an equation directly. Just put in something like V=sin((6.28*time*10k) * time)
  • Country: ar
« Reply #5 on: February 14, 2015, 08:32:01 pm »
AC analysis?
Thanks for that!  :-+
Agustín Tomás
  • Country: ar
« Reply #6 on: February 15, 2015, 07:20:03 pm »
AC analysis?
Sorry. You were RIGHT. What I did not want was exactly that: .ac analysis. My bad. :palm:
Agustín Tomás
