Author Topic: Reverse engineering a classic audio product?  (Read 737 times)
Offline cvancTopic starter
« on: February 21, 2020, 04:53:22 pm »
OK audio types, here's something you don't see every day...
Attached is the schematic for the Beveridge Electrostatic loudspeaker model 2SW-1.  Back in the day it was argued to be one of the finest speakers ever made.  Let's figure out how it works.
It has a built-in hybrid amplifier that uses tubes for the output stage.  The configuration is novel, allowing for transformerless drive to the transducer panels.
I would love to discuss how the output stage works.  Especially how does it bias the driver transistor pair, and how does the output node of the tubes stabilize at a quiescent state halfway between +HV and ground?  I am not visualizing it...
Thanks!
Offline duak
Re: Reverse engineering a classic audio product?
« Reply #1 on: February 21, 2020, 06:55:24 pm »
R1 & R3 look like feedback resistors to the driver stage.  A higher cathode voltage on V201 & V203 leads to more base current into Q108 & Q109 then Q110 & Q111 turning them on harder, pulling the grid voltages of V202 & V204 up causing their plate voltages to fall and bringing the cathode voltages back to nominal.  The actual voltage is a function of the voltage of the -60V rail and the values of the various resistors in the feedback circuit.
« Last Edit: February 21, 2020, 06:57:17 pm by duak »
