Author Topic: Reverse Engineering a IR Blaster  (Read 3512 times)
Offline bizkitsTopic starter
  • Country: sg
« on: April 06, 2024, 12:01:43 pm »
Hi everyone, recently I purchased a Type C IR Blaster (https://de.aliexpress.com/item/1005006058268428.html?gatewayAdapt=glo2deu).
It works on an Android with their application Ocrustar.
However I want to make it work on a raspberry pi or microcontroller.
I pried open the IR Blaster and in it I see a microcontroller WCH 552ED06. But I can't find any documentation on this chip.
I did some research and think that it could be a chip which provides USB + IrDA (some kind of IR Specifications)?
My next step is to somehow get hold of information on how to write codes to communicate with the chip on a computer.
Anyone has any idea how/what I should search in order to start?
*attached is the image of the IR blaster
Offline zilp
Re: Reverse Engineering a IR Blaster
« Reply #1 on: April 06, 2024, 12:52:11 pm »
This is what you are looking for:
https://www.wch-ic.com/products/CH552.html
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: April 06, 2024, 01:01:46 pm »
Just use an IR LED and a simple one transistor driver.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
The following users thanked this post: bizkits
  • Country: sg
« Reply #3 on: April 06, 2024, 01:24:29 pm »
Thanks, but how do you know is this chip?
Offline DavidAlfa
« Reply #4 on: April 06, 2024, 01:27:47 pm »
Try decompiling the apk in https://www.decompiler.com/
There's an interesting file: sources/com/esmart/ir/IROTG.java
And the function sendIRDataToExternalDevice
Offline wraper
  • Country: lv
« Reply #5 on: April 06, 2024, 01:28:00 pm »
Because obvious marking.
  • Country: sg
« Reply #6 on: April 06, 2024, 01:56:19 pm »
Thanks for taking a look at the apk.
Yeah I was looking into that just now and saw that method too. Will try to figure out how to replicate it in maybe a simple app.
  • Country: sg
« Reply #7 on: April 06, 2024, 01:57:10 pm »
Ahhh 552 on the chip! How did I missed that  :palm:
Thanks for pointing that out
Offline honeycat
« Reply #8 on: April 24, 2024, 11:57:20 am »
These might help
