Author Topic: floating differential amplifier instrument cable type ? Twinax vs triax  (Read 1198 times)
Offline sarepairman2Topic starter
I have a HP8904A function generator. It has the option of fully differential floating output. It has 2 BNC connectors (center pin hi, center pin low, the shields are connected to earth ground)
Is it better to use a triaxial or twinaxial cable to link things to the instrument?
I.E.
Shield (Earth) (outer shield)
HI  (center pin)
Low (inner shield)
vs
HI   twisted pair
Low    twisted pair
signal to 600KHz only.
impedance of amplifier output : 50 ohms
« Last Edit: September 12, 2015, 10:35:17 pm by sarepairman2 »
