Hello! I want to make a cool hexapod robot, and I found these actually pretty decent, but more importantly CHEAP serial bus servos on amazon. They are Lewansoul LX-16A servos.
http://www.lewansoul.com/product/detail-146.htmlThey have all metal gears, a continuous and angle mode, decent torque at 17kg/cm at 7.4V, you can daisychain them on a serial bus like dynamixel servos and have up to 253 of them. I think it uses the same protocol as them, actually. You can even read motor temperature and current angle back over the serial link! All this for 14.99USD!
There are a few downsides, though. The motor is apparently a little overvolted, so if you run it at 7.4 and at max load for long, you're going to fry it. But its a common size, and replacements of a suitable voltage rating can be had for only a dollar or two. I don't plan on maxing them out too badly, and I will run them at a little less voltage.
Something really nice is the 3D cad reference they come with appears to be the same one they use to make the servo, as it contains all the gears and internal shafts, the pcb and its mounts, the potentiometer, motor, bearings.. etc. I've never seen that provided as a cad ref before.
This brings me to what I want to do. I want to try to see if its possible to add some features to this little servo, like PID control. Right now it appears to have a very basic control loop, with some overshoot if you move fast.
I can not identify the microcontroller, and before I design my own drop in replacement PCB, I'd love to see if it was possible to just reflash the firmware on board. I have pulled this number from the top of the cpu, and this is what it looks like:
HL 004
642GB
2634B071
ARM
So does anyone know where I can start trying to do this? I admit I have very little experience with microcontrollers outside of the arduino compatible atmega realm..
