Author Topic: LMX2582 sine or square wave output (RF Synthesizer with Integrated VCO)  (Read 1498 times)
Offline sorinTopic starter
Please can anyone tell me what output should have this Synthesizer, sinewave or squaewave?
Ther are 2 type of outputs, direct from VCO and the other from the counter output
Can we use this Ic as a signal generator?
Thanks in advance!
http://www.ti.com/product/lmx2582
Datasheet:
http://www.ti.com/lit/ds/symlink/lmx2582.pdf
Offline danadak
The output of the VCO is a squarewave, the counter out a pulse
with varying duty cycles depending on /n and fractional divider
logic.
If you want a Sine, Triangle, Saw, Square then a DDS chip more appropriate.
http://www.analog.com/en/products/rf-microwave/direct-digital-synthesis-modulators.html
Regards, Dana.
Offline SaabFAN
I doubt there is a cost-effective DDS-Solution available that can generate a sine-wave in the 5Ghz-Range.
A sine-shaping circuit to turn the square-wave into a sine-wave would probably the best solution.
TI has an application-note about that topic.
