I recently scored a nice Technifor Lasertop 410 laser engraver system; not quite as cheap as one of Dave's dumpster finds, but not far off it! The unit is complete except for the PC that runs the software; I'm advised it recently had a new pump laser installed (confirmed), but the system went wrong and it was considered too expensive to bother repairing it. There's very little technical documentation available, and the UK agent refuses to help with 2nd user equipment (so much for recycling and reuse!). What I do know is the interface to the PC is RS-232 and is at 19200 Baud, no indication of stop bits or parity though.
Having torn it apart, the controller is based on a PC/104 SBC plus a laser interface card, a scanner driver and power supply board, and an optically isolated interface board. The SBC is an Erim ALICPU6117-104 with the ALI 6117 processor; it has 2 RS232 ports and an RS485 port, a couple of parallel interfaces (listed as being suitable for a graphics LCD panel and a 56 key keyboard), and an IDE interface. Sadly the Wayback machine doesn't have the data sheet for the SBC archived and I can't locate a copy anywhere. I've looked at the 2 serial ports at startup and they both put out a few characters at bootup and feeding a data stream in to one of them does halt the boot process, so it is configured to generate an interrupt on received data. I cannot get any other repsonse from either serial port. I'm now thinking that it may be worth trying to boot the SBC from an IDE drive into a basic Linux with a TTY on one of the serial ports, then reading the filesystem from the flash storage. Does this seem like a reasonable approach?
