Electronics => Projects, Designs, and Technical Stuff => Topic started by: andtfoot on December 29, 2013, 11:36:58 am
Title: Reverse engineering the Fluke WireView identifiers
Post by: andtfoot on December 29, 2013, 11:36:58 am
After recently purchasing the Fluke LinkRunner AT 2000 (thanks to TopLoser  :-+ ), I looked at getting more of the cable identifiers. After seeing the price (>$400).... bugger that.
I thought I'd see if I could make my own.
I was fully expecting some termination resistors, and maybe an EEPROM with the identifier number stored.
Instead I got this (please excuse blurry phone pics; my camera is at work):
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-NmqvhdJ/0/L/WP_000616-L.jpg)
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-PvQH3GC/0/L/WP_000614-L.jpg)
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-VvFSKt5/0/L/WP_000618-L.jpg)
I scanned the circuit board and whipped up a quick overlay:
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-gZdD3D9/0/L/fluke0001-L.jpg)
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-hrNrQGB/0/L/fluke0002-L.jpg)
I'll be figuring out the circuit shortly.
In the meantime, has anyone got any ideas on how the Identifier number might be set on this? There are 1 to 6 available, and this is #1.
Title: Re: Reverse engineering the Fluke WireView identifiers
Post by: amyk on December 29, 2013, 11:53:18 am
The value of the resistors, almost certainly.
Post by: dfmischler on December 29, 2013, 11:58:11 am
If it isn't the resistors then the units could be wired differently to the connector (i.e. three diodes could provide a three bit binary code quite easily).
Post by: mikeselectricstuff on December 29, 2013, 12:40:05 pm
Once you have a schematic I suspect it will be fairly obvious which parts will be used to distinguish units - almost certainly either a resistor value or a ratio of 2 resistor values,
Post by: mcinque on December 29, 2013, 02:53:47 pm
>400$?  :wtf: :rant: This is the evidence that some manufacturers tend to easily overprice their accessories not for their quality but only because their brands are well known.  :--
Post by: andtfoot on December 29, 2013, 04:19:41 pm
I should clarify, the $410 is for a set of 5 (#2 to #6), but that still means $82 each...  :palm:
I tend to agree with the suggestions of the resistors being used to set the number. I've thrown together a schematic, but with no values yet. For some reason what measure doesn't seem to match the markings. e.g:
R1 (the one on the far right of the top picture) measures 25.07k, but marked 390 (39R) or 39C(?) maybe
R6 and R9 measure 10.6k, but are marked 1432 (14.3k)
R12 measure 3.836k, but is marked 57B (?)
I might pull a couple out of circuit to double check, but I wouldn't have thought these would be affected.
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-BTwTQHd/0/O/flukeschem1.jpg)
Post by: mikeselectricstuff on December 29, 2013, 05:00:22 pm
Letters are equivalent to digits : 57B = 572 = 5K7
Low readings will be due to the parallel combinations
A bit puzzled about the large R's, unless it's a test load for 48V PoE
Post by: mcinque on December 29, 2013, 05:04:46 pm
Much better  ::) But still overpriced!
Post by: andtfoot on December 29, 2013, 06:17:12 pm
Rightio, thanks.
I wouldn't have thought a resistor such as R1 would be affected by any parallel combinations. I'll have to double check after I've had a nap...
The Linkrunner measures PoE, but I don't think it spits out any. That said, these identifiers appear to be used across a few products so maybe something else does.
If I were to have a hunch based on an uneducated guess  ;D I'd say that the Schottky diodes are being used as comparators of sorts; the voltage dividers made by the resistors are used to set which diodes are forward biased.
Another possible theory is that the large resistors are being used as a precision reference (why else would you have series-parallel like that of the same value, apart from increasing power capacity). Maybe the comparison between this and the other resistors is done at the LinkRunner end.
First thing I'll probably do after figuring out values is breadboard it and see if I can get a copy working. Then I can tinker......
Post by: tinhead on December 29, 2013, 06:22:08 pm
wrong, 57B ist not 5k7 but 3k83
http://www.talkingelectronics.com/projects/ResistorsMadeEasy/SMD-Resistors-EIA-Markings.html (http://www.talkingelectronics.com/projects/ResistorsMadeEasy/SMD-Resistors-EIA-Markings.html)
Post by: andtfoot on December 29, 2013, 06:23:40 pm
Could you please explain how you got that so I can see if it matches with the rest?
Edit: Hmm, found something that explains it a bit:
www.marsport.org.uk/smd/res.htm (http://www.marsport.org.uk/smd/res.htm)
Post by: TopLoser on December 29, 2013, 06:26:45 pm
http://www.hobby-hour.com/electronics/eia96-smd-resistors.php (http://www.hobby-hour.com/electronics/eia96-smd-resistors.php)
Glad you like your new LinkRunner!
Post by: andtfoot on December 30, 2013, 02:27:06 am
Ok, here is the latest with the values read off the components. I've also rearranged it a bit to try and find patterns in how the components are connected.
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-LKmn6j9/0/O/flukeschem2.jpg)
Post by: andtfoot on January 08, 2014, 06:42:10 am
I finally found some schottky diodes and sat down with the breadboard.
I don't have the correct value resistors, so I tried the closest values I could:
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-sP6qxZ7/0/L/WP_000631-L.jpg)
Not close enough apparently...
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-P8SS2xX/0/L/WP_000630-L.jpg)
I'll get a bunch of the correct resistors and try again (and double check my breadboard mess  ;D ).
I couldn't measure the capacitors (value too small for my DMM), so I took a punt with 22pF ceramics. Maybe this is a good excuse to pick up an LCR meter, not that the value should be important.  :-DMM
Post by: amyk on January 08, 2014, 07:48:08 am
Could all the stray capacitance/inductance of a breadboard be enough to upset it?
Post by: andtfoot on January 08, 2014, 07:53:02 am
It's possible. I did connect the original module through the breadboard and it worked fine there, but it's obviously a lot neater.
I was hoping whatever signals it uses would be quite robust, given it may have to go ~100m of cable in normal usage. Some of the resistors are a fair bit out, so it can't hurt to try that first.
Post by: Rerouter on January 08, 2014, 09:06:48 am
Just to pretty it up if you get anywhere with it, heres my take on the circuit,
Post by: andtfoot on January 09, 2014, 03:23:39 am
Thanks. The general layout looks like it will be easier to find patterns with.  :-+
It looks like I'll probably concentrate on the 4 right-hand resistors (R4, R11, R12, R15) to start with.
One small error though, is the missing RJ-45 shield and how the last diode connects to it.
On other news....
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-Nxg3TC8/1/L/WP_000632-L.jpg)
Like a bought one!  8)
I started by compacting it all and shortening the wires; no good. Then swapped the resistors out for combinations that got me within 100R or so.
It means I can churn out a bunch of #1 units if I feel like.
Next step will be grab some scope shots, and start swapping values. I might also disconnect a few diodes one at a time to see if them conducting or not is determining the ID.
Post by: andtfoot on January 09, 2014, 03:32:15 am
First bit of random discovery:
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-PN9GkT6/0/XL/flukeschem2%205-XL.jpg)
I can get the ID to change from #1 to #5 if I disconnect this wire going to pin 3 of D2.
Post by: andtfoot on January 09, 2014, 06:37:34 am
First scope shots, with ground on pin 8, and probe on pin 1.
Idle, there seem to be random pulses (which aren't there when the tester is turned off). Could be something to do with the network testing side of things.
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-bCG55LF/0/O/1%20and%208%2C%20idle.jpg)
This is when doing a test:
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-mjgMMRL/0/O/1%20and%208%2C%20scanning.jpg)
Post by: Rerouter on January 09, 2014, 06:50:37 am
based on the arrangement, try measuring across 4 and 5, i would imagine that should just be a fixed voltage,
(also i mistook that 9 to be 8, so the diode that curls around the right on my diagram is the diode to case)
Post by: andtfoot on January 09, 2014, 08:12:25 am
Measuring with probe on 4, ground on 5.
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-3x8V75m/0/O/4%20and%205%2C%20scanning.jpg)
No random pulses (which makes sense if it is a network testing signal).
Post by: andtfoot on January 14, 2014, 09:18:09 am
I've had a fiddle around, swapping the 4 resistors going to the diodes, reversing the diodes, changing value of that series/parallel resistor set, etc.
No luck apart from that #1 -> #5 when disconnecting a wire thing (probably just coincidental) I posted earlier.
To be honest, I'm pretty lost where to start looking or what to try. Has anyone got any ideas they could throw at me please?
I've also ordered a batch of circuit boards from ITead matching the existing one. First time I have done that, so at least it's still a good learning experience.  :)
Post by: Rerouter on January 14, 2014, 09:23:02 am
try moving the diodes connection from 6 to 7
and / or R4's connection to pin 6,
my head is screaming at me about the non symmetry in the diodes center connection
Post by: tonyv on March 25, 2014, 10:36:33 pm
Hi AndtFoot !
I'm also an owner of a LRAT2000, it is an outstanding piece of equipment. I also share your thoughts about that those little WireView adapters are very expensive, and actually overpriced.
I also own a Microscanner2. Its included cap/lid is also the receiver, if used with the LRAT2000 it is detected a WireView1, i will extract it and photograph it for you so you can compare.
But i discovered something, the integrated reception port of the LRAT2000 (the lateral RJ45 port) is detected as Wireview 7 with the Microscanner2 !!!
I think that you should open your unit and verify that portion of the circuit, i think that you may find a clue there.
Hope that this project is still alive !
Post by: andtfoot on April 20, 2014, 01:50:39 pm
Well... after a loooong time, I've finally got around to looking at this again. Thanks for the suggestions in the meantime.
I ended pulling apart the main unit (goodbye warranty ;) ) to look at its loopback circuit.
It appears to be identical with the exception of R12, R11, R4 and R15 below (unit #1). They are double the value in the loopback.
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-P59dHRc/0/L/wiremap2-L.jpg)
This triggered a memory of a pattern I'd noticed earlier in unit #1:
The ratio of the the resistor leading to the diodes to the other resistor(s) that the diode is across is 1:5
e.g. R12 * 5 = R2,
R4 * 5 = (R3 + R8 + R5),
etc.
The ratio of the loopback unit is then obviously 1:10.
So I've ordered a bunch of resistors to suit ratios 1 through to 10; more experimentation to follow once these are received.
In the meantime, production of identifiers using parts I already have has begun......  :-/O
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-pndtWWf/0/L/IMG_0804-L.jpg)
Post by: menkelis on April 26, 2014, 03:18:24 pm
Just passing on some information, might be useful. I have a Fluke Lanmeter 683 and asked user Khashoggi
who also has/had a 683 a question on ID plugs (search for 'Lanmeter 630'  in Test Equipment).
I am happy to report I have identifiers 0,1,2,3,6 (similar small form factor)
And identifiers 8,9,11,12 which are double-width of the other
small form factor identifiers.
You appear to be using the T568A wiring so that is what I will
use. I'm using a Fluke 45 for these measurements and am rounding
from the thousands to the tenths-
ID 0
1-2 18.7K
2-3 16.6K
3-4 15.8K
4-5 14.1K
5-6 12.7K
6-7 11.2K
7-8 10.0K
ID 1
1-2 180.7K
2-3 80.7K
3-4 99.9K
4-5 180.6K
5-6 74.7K
6-7 INF
7-8 INF
ID 2
1-2 182.2K
2-3 82.2K
3-4 100.0K
4-5 182.2K
5-6 75.0K
6-7 INF
7-8 INF
ID 3
1-2 183.4K
2-3 83.5K
3-4 100.0K
4-5 183.4K
5-6 75.0K
6-7 INF
7-8 INF
ID 6
1-2 188.7K
2-3 88.7K
3-4 100.0K
4-5 188.7K
5-6 75.0K
6-7 INF
7-8 INF
ID 8
1-2 191.7K
2-3 91.2K
3-4 100.0K
4-5 191.7K
5-6 75.1K
6-7 INF
7-8 INF
ID 9
1-2 194.2K
2-3 94.2K
3-4 100.0K
4-5 194.2K
5-6 75.2K
6-7 INF
7-8 INF
ID 11
1-2 205.5K
2-3 105.3K
3-4 100.2K
4-5 205.5K
5-6 75.3K
6-7 INF
7-8 INF
ID 12
1-2 224.9K
2-3 125.2K
3-4 99.7K
4-5 224.9K
5-6 75.1K
6-7 INF
7-8 INF
Post by: menkelis on April 28, 2014, 03:17:27 pm
WireView Wiremapper Use and Interoperability - EtherScope
EtherScope ships with a far end adapter 1 labeled WireView.
The WireView far end adapter is used on installed cable links to obtain wiremap results.
EtherScope reads the adapter ID and reports the value on the Cable Verification screen.
Shown below are the wiremap adapters supplied with products:
•OneTouch
•OptiView Integrated Network Analyzer (Series I and Series II only)
•EtherScope
•LANMeter
Cable identifiers shown are all interoperable.
Post by: andtfoot on May 01, 2014, 12:13:25 pm
Some success!  ;D
Tried a ratio of 6 first up (first number I pulled out of the bag of resistors).
No good.
Tried a ratio of 3, which led to...
(http://andtfoot.smugmug.com/Electronics/Fluke-WireView/i-jGQC3ck/0/L/WP_000767-L.jpg)
ID of 2 found!  :-DMM
Further testing of other ratios to follow........
Post by: andtfoot on May 01, 2014, 02:04:37 pm
Results of the rest of the ratios I bought resistors for are in:
IDRatio
15 (measured and based on original)
23
32
Loop9
Loop10 (measured and based on original)
When I get some time again I'll try some ratios between the whole numbers (e.g. 1.5).
Post by: menkelis on April 17, 2015, 06:47:49 pm
Well it's bee a while, and I just acquired a Fluke 620 LAN Cable Meter with the optional eight
cable-id plugs.
They look exactly like the cable-id plug that came with my  Fluke Lanmeter 683, but unfortunately
they are not the same beast.
The Lanmeter 683 reports mis-wired  ID when trying out the 620 cable-id plugs.
Trying the 'cable map' function reports open's and mis-wires on these id plugs.
The Fluke 620 reports invalid 'ohms' when trying out the Lameter cable-id plugs in it.
Not a 100% lost cause, as I can still use the 620 cable-id plugs as intended with the
620 cable meter for ID'ing unknown/unmarked cables.
Post by: menkelis on July 16, 2015, 03:56:25 am
I now have a official set of 0 - 6 "cable identifier" plugs for my 683.
I opened up the ID #1 plug to see what it was like inside and have attached
a photo of it.
Post by: coreyspeed on November 08, 2015, 03:11:23 pm
I was wondering if anybody ever got any further on this project, I have just purchased a Fluke linkrunner, and would like the extra remote's, it looks like I can make ID's 1-3 and then try and produce the other values.
Also would you be able to provide the values used for ID 2 and 3 for resistors R12,R11,R4,R15. My Maths doesn't appear to be getting anywhere near the values for wireview 1
Post by: coreyspeed on November 09, 2015, 12:48:13 pm
Got hold of the Fluke Microscanner at work today and the WireMap top on the unit comes apart very easily.
Measured the capacitors and they read at 22pf.
Took some pictures appears to have more components then the listed on this thread.
(http://s12.postimg.org/r8g45t9x9/2015_11_09_12_43_18.jpg)
Post by: kamcm on November 09, 2015, 07:35:08 pm
Coreyspeed, the item you pictured is a main Wiremap adapter instead of a WireView identifiers.
http://www.amazon.com/Fluke-Networks-CIQ-WM-Wiremap-Adapter/dp/B00094OWGA (http://www.amazon.com/Fluke-Networks-CIQ-WM-Wiremap-Adapter/dp/B00094OWGA)
(http://ecx.images-amazon.com/images/I/41vXkXXThHL.jpg)
May you please post more clear pictures with it?
I want to make one on my own.  :-DD
I recently purchased a Fluke CableIQ tester off eBay, but it didn't come with a Wiremap adapter. |O
Post by: coreyspeed on November 10, 2015, 12:06:54 pm
Hi
Yes this is correct, I have a WireView number 1 as well, both are ID's appear as 1 on the units. I believe the extra components maybe for the F-Connector.
I am going to create a schematic this weekend to see how they compare to each other
Would be interested to know how the original poster removed the casing from the WireView with out damaging the casing, mine appears to be stuck in their.
Post by: coreyspeed on November 10, 2015, 05:56:15 pm
It  appears that the red section in the picture is R1 and R12 this is only connected to the F connector and therefore ID's this as number 1.
Post by: timofonic on November 15, 2015, 11:46:56 am
I'm really intrigued about this. I didn't know there was so much tools for cablee impedance and such.
Could someone provide a layman introduction or  URLs about all this? Please, I'm curious...
Post by: turbotim on August 29, 2017, 05:19:05 pm
Hi There,
I know its been a long time, but did anyone manage to crack this one?
Post by: andtfoot on September 01, 2017, 11:41:52 pm
Hi There,
It's on my very long 'rainy day' list, but the 4 IDs I figured out of 7(?) possible is enough for my purposes so it's relatively low priority at the moment.
Post by: sayit on January 20, 2018, 04:16:39 am
CableIQ wiremap tested
RK45 8pin
attach cable with WM Autotest->Port or cabling short Autotest not available
not join WM Autotest-> without wire map test OK
DIAG—>Continuity test all OK
Blinking  port light test OK
Telco 2pin (4-5)
attach cable with WM Autotest-> not find wire map continue no WM-> then yes->cable length ok
COAX
AUTO TEST MAP ID are “?” other OK
teardown main unit without LCD unit and checking use microscope
clean PCB board resolder any parts..
same work wiremap unit
But a not changes result.
Whats happen? please your help.
http://www.chitosecity.com/flukes/CIQ.pdf (http://www.chitosecity.com/flukes/CIQ.pdf)
(http://www.chitosecity.com/flukes/cableIQ-bk0.jpg)
(http://www.chitosecity.com/flukes/cableIQ-f.jpg)
(http://www.chitosecity.com/flukes/CIQ-WM01.jpg)
(http://www.chitosecity.com/flukes/CIQ-WM02.jpg)
Post by: ben_r_ on January 25, 2018, 04:28:57 pm
Has anyone confirmed that this circuit is the same as the Remote IDs Fluke makes for the MicroScanner2?
Post by: cmu2017 on October 27, 2018, 04:44:33 pm
Does anyone know how they check if some wires are crossed?
Post by: jasom on November 10, 2018, 09:43:15 am
Hello, have someone photo of Fluke Microscanner2?
I have one with damaged one zener diode but I have not information about that model. (VR1 position)
Post by: cmu2017 on November 30, 2018, 09:41:22 am
What are the values of the diodes and capacitors on the  schematic made by user andtfoot
Post by: andtfoot on December 15, 2018, 09:26:00 am
For the diodes I used the Broadcom HDMS-2802-TR1G schottky.
https://au.element14.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=43&urlRequestType=Base&partNumber=1056834&storeId=10184 (https://au.element14.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=43&urlRequestType=Base&partNumber=1056834&storeId=10184)
I don't how important the actual value/part is, just that it's a schottky.
For the capacitor, I think I used a 10nF or 1nF ceramic; I can't check at the moment though to confirm. I don't think I could ever actually measure it from the original.
Post by: cmu2017 on December 16, 2018, 02:45:18 pm
Ok, thanks
Post by: electroboy on January 14, 2019, 02:39:26 pm
Fluke Main Wiremap
Hello Andfoot, I have a Fluke Networks Cable IQ qualification tester with this main wiremap, but it has a problem, the tester not recognizes it, when I connect it at far end it appears like nothing connected. The problem comes out because it got connected to a POE Ethernet switch by a partner at work.  My question is? Do you have the circuit for this main Wiremap? I also need help with this component, which is marked as WK3 and is SOT-23 package, CG marking code 3 pins SOT-23, I can’t find it and I don’t know if it is a transistor or a diode. Thanks a lot
Post by: KuchateK on February 16, 2019, 03:35:29 am
Just dropping pic of the VR1 if you still need it. I have same rev on the pcb as you.
Quick measurement: 3.3v on the plus side relatively to battery negative terminal. Let me know if you need more measurements.
Post by: kripton2035 on March 09, 2019, 07:49:56 pm
(https://www.cjoint.com/doc/19_03/ICjtXtj1qmz_wiremapper.png)
Post by: jasom on March 10, 2019, 12:27:12 pm
KuchateK: Thanks so much, I have still this problem so now I can try to repair it. I will say if it works or no.
Post by: jasom on March 23, 2019, 04:42:38 pm
Hello, I have a new problem .Can anyone tell me what is circled smd on picture? Sign on it is "5T8 RRN"
(https://i.imgur.com/y55xvPZ.jpg)
Post by: kripton2035 on May 08, 2019, 03:02:07 pm
could you please check between the two schematics below.
there is a mix between pins 9,8 and 1 the schematics are not the same.
I tried both of them and none works for ID#1
can someone please confirm which one is the good one ?
thanks.
Post by: kripton2035 on May 08, 2019, 03:03:42 pm
I can get the ID#1 on the fluke nettool 2 display, but it tells me wires 1-2-3-4 are not wired correctly.
Post by: t523993 on September 15, 2019, 06:47:03 pm
I look for scheme for wiremap adpater to Fluke Microscanner I. Who have this scheme?
Post by: hopto on December 11, 2019, 12:56:45 pm
Hello. Can you take photos of the microscanner2 and CableIQ printed circuit boards  from all sides?
Post by: martonbaksa on June 20, 2020, 07:46:42 am
Hey y'all,
You mention these WireView identifiers, are those compatible with the OneTouch Series II. According to the manual the part number for those is: N6600/RA but those don't look the same as yours, but I read on eBay that the newer ones are compatible with most older fluke units. I am not sure if I want to go down the road of making my own off these schematics unsure of if it will work.
Thanks,
Marton
Post by: Nifty on May 18, 2021, 08:05:12 pm
LinkRunner WIREMAP schematic
by Lawrence Billson
upverter.com/design/lawrencebillson/4ae5e357c2db7191/linkrunner-wiremap/ (http://upverter.com/design/lawrencebillson/4ae5e357c2db7191/linkrunner-wiremap/)
Post by: ediaz on October 26, 2021, 09:08:00 am
Will be great if somebody share the info about this to be able to replicate the process and create new ids..
@andtfoot can you share the gerbers and the lasted info? if you can, thanks a lot I will post my summary here :-D
Post by: ahrenolog on November 13, 2021, 05:58:26 pm
Hello colleagues . The following analyzer came in for repair - Fluke Networks NetTool Series 2. There were charging problems. They asked me to make identifiers, I worked in the evenings for a week, that's what happened. https://youtu.be/v9sYhZtopYk
Post by: jasom on April 30, 2022, 12:08:56 pm
Hello, its some time but, if You still can do some measurements on this device. Can You please check what voltage is on U13 on pin 6 (Vin) when You press start button?
I have 3.2V
Thank You very much
Post by: morphis on May 23, 2023, 09:29:02 am
@andtfoot Thank you for your initial work with the schematic.
I've been needing to repair my ID3 and ID4 WireView Cable ID units (Broken tabs).
So as I had to de-pot them I have some more info, and I've also measured the loopback inside my LinkRunner AT-2000.
Resistors R2, R3, R5-10, R13, R14 are the same values for each ID and the internal loopback
The internal loopback only has a single 14K3 (R4) between pin 4 and 5, Where as the Cable ID units have 4 resistors (R6-9) in the parallel-series arrangement.
Its also missing the pin-9 shield test components (R1, D5, C5).
So the only components that set the ID are R4, R11, R12 and R15
ID0ID1ID3ID4
R44.32K8.66K21.5K34.8K
R111.69K3.4K8.45K13.7K
R121.91K3.83K9.53K15.4K
R152.15K4.32K10.7K17.4K
Has anyone else have values for R4, R11, R12 and R15 from other IDs?
https://docs.google.com/spreadsheets/d/16VslfwP_YgZnVYq4AyuuF9MA8dwQInBXGkP8JXn2l00/edit?usp=sharing (https://docs.google.com/spreadsheets/d/16VslfwP_YgZnVYq4AyuuF9MA8dwQInBXGkP8JXn2l00/edit?usp=sharing)
Post by: javier.lopez.vlc on July 12, 2023, 10:36:02 pm
Hi, I know this topic is long overdue, but I cant find a schematic to replicate the Fluke Cableiq WireView adapter.
Has anyone gotten any information on this?
They want to charge me more than €200 for a piece of plastic and two connectors. An abuse.
Thank you for your time.
Post by: AVENZ on February 05, 2024, 10:46:34 pm
 :-+ Gracias por tu aportacion, fue de ayuda para hacer lo mismo en un equipo UNI-T UT685B. El texto impreso en el PCB marco 2 capacitores (C79 & C1) pero son resistencias realmente.
Intentare fabricar ID's con la informacion del Post pues hay demasiadas similitudes de diseño.
El UT685B no cuenta con ID's a la venta por el momento (Espero estar en lo correcto).
Saludos a todos.
CX=1nF
D=Diodo Schottky
Post by: AVENZ on February 25, 2024, 12:57:12 am
Ya mande a fabricar la PCB, monte los componentes y fue todo un exito. Ahora toca fabricar otros ID`S.
Post by: gabrieldevriendt on June 02, 2024, 03:46:11 pm
hey guys, anybody has a files to update higher as 2.5.4 build 1110?
If anybody needs the 2.5.4 build 1110 I can for sure also provide those files
Post by: CountParadox on September 07, 2024, 11:05:50 pm
Any info on what those capacitors are in the above diagram? Trying to replicate this work !
Post by: kripton2035 on September 08, 2024, 07:30:12 am
I recall using 10nF for this.
Post by: eta10mcleod on September 29, 2024, 04:07:09 pm
I was able to log in to the console of my Fluke LinkIQ.
Running a cable test via console prints out all the measurements the device takes.
I have attached the measurements for every Remote ID, I hope this helps.
Post by: morphis on October 17, 2024, 01:06:08 pm
Ive found the values from ID5
R12  21K
R11  18.7K
R4    47.5K
R15  23.7K
Ive updated https://docs.google.com/spreadsheets/d/16VslfwP_YgZnVYq4AyuuF9MA8dwQInBXGkP8JXn2l00/edit?usp=sharing
I think Ive calculated the values for the missing ID2 ID6 and ID7
I have also seen photos of ID8 - ID12
Post by: morphis on October 24, 2024, 11:09:48 am
I now have all the values fro ID0 thru to ID6
These values are based directly on the SMD markings for ID1 thru ID6.
For ID0 (the internal loop back port) the values for R11 R12 and R15 are measure in circuit (forward and reverse, highest value is used), the measured values match the expected values.
#     |ID0    |ID1    |ID2    |ID3    |ID4    |ID5    |ID6
R121.91K3.83K5.76K9.53K15.4K21K30.9K
R111.69K3.4K5.11K8.45K13.7K18.7K26.7K
R44.32K8.66K13K21.5K34.8K47.5K69.8K
R152.15K4.32K6.49K10.7K17.4K23.7K34.8K
I think the following is the scheme is use to calculate R4 R11 R12 R15 for each ID
ID0 X 2 = ID1
ID0 + ID1 = ID2
ID1 + ID2 = ID3
ID2 + ID3 = ID4
ID2 + ID4 = ID5
ID3 + ID5 = ID6 ( R11 is only off by 700ohms from the actual marking on part )
These are all fitted to the E96 series at each step.
I've updated the Google sheet (https://docs.google.com/spreadsheets/d/16VslfwP_YgZnVYq4AyuuF9MA8dwQInBXGkP8JXn2l00/edit?usp=sharing) with the actual values for ID 0-6 and the estimates for 7+, you can see the function used to cal and fit the estimate.
Post by: PVK on November 19, 2024, 09:57:55 am
Hi All!
I am looking for the wiremap identifier of the fluke 620
Can you help me? Please!
I have one in use :D
Post by: BennoG on November 19, 2024, 10:12:29 am
Hi All!
Me too, I have a x-ray image of one.
Benno
Post by: netufo on November 26, 2024, 09:48:11 am
I have fabricated ID7 and ID8 according to the parameters you released. However, they cannot be recognized normally on the LinkRunner 1000.
Post by: evac on January 17, 2025, 10:51:36 pm
I made a small PCB to try this for my NetTool series II which I bought without accessories, and at least for ID1 seems to work fine.
I used 0.5% 0603 resistors, some random 0805 1nF caps and BAT54S diodes.
Many thanks to andtfoot for the schematic and for morphis for the handy excel sheet!
Post by: kripton2035 on January 19, 2025, 08:36:43 pm
I also made a few pcb for my identifiers. I did make 4 of them.
Post by: Oleg_K on March 02, 2025, 03:49:15 pm
Hi! I recently purchased a NetTool Series 2 on eBay, and everything works well except for the WireView wiremapper. When I connect it to the device, it shows an incorrect wiremap, as if the cable is improperly terminated.
Ordering another identifier is risky due to long shipping times and the possibility of receiving one with the same issue. Since I’m not very experienced in reverse engineering, I was hoping you could help me by providing a PCB schematic for the WireView identifier. This would allow me to have a replacement board made.
I came across your article and saw that you also have a NetTool Series 2. From what I read, you successfully designed and built a working schematic. That’s why I’m reaching out—your expertise would be incredibly valuable in helping me get this issue resolved.
I’d really appreciate any assistance you can offer!
Post by: BennoG on August 19, 2025, 08:14:58 am
Hi All!
fot the 620 see  https://www.eevblog.com/forum/projects/fluke-620-lan-cablemeter-remotes/ (https://www.eevblog.com/forum/projects/fluke-620-lan-cablemeter-remotes/)
Post by: field_tech on November 11, 2025, 04:43:12 am
According to Claude and inputting some details from the manual this is what it analyzed. Hope this helps someone determine how the unit is testing cables.
Post by: field_tech on November 12, 2025, 12:50:46 am
Has there been any progress made on this ? Like gerber files and BOM to replace my broken adapters, would love to not have to spend hundreds of dollars to replace them....
Post by: BennoG on November 12, 2025, 08:35:28 am
If it is broken open it up and post high res photos of all the components.
So all markings are readable.
Benno
Post by: MIKEFL0 on December 21, 2025, 09:56:04 pm
Excuse me if this is a dumb question to ask:
Are the Remote ID plugs that are used on the Microscanner 2 and the Wireview Cable ID plugs used on the Net-tools Series II one and the same or are they not compatible?
Post by: BennoG on December 22, 2025, 06:53:35 am
they are not compatible (found out the hard way)
Benno
Post by: MIKEFL0 on December 22, 2025, 09:39:39 am
I was thinking that may be the case  :(
Thank you Benno.
Mike
Post by: MIKEFL0 on December 22, 2025, 10:45:16 am
Having spent another hour or so going through this very informative thread, my thanks to all the contributors, it seems like information on both the remote ID and the cable ID plugs are included.
If I've understood correctly, both type of ID plug share the same schematic, but using different circuit references and difference resistor values.
So is it a practical proposition to convert a cable ID plug to a remote ID plug, just by changing the resistor values?
Plus, how easy is it to break open the enclosure and is the PCB potted?
Post by: MIKEFL0 on December 22, 2025, 12:25:13 pm
Well, I can scrub my last post, I'm pleased to say.
Having just purchased a new Fluke Link IQ, as well as a set of six second user WireView Cable ID devices, I'm delighted to report that they all work with one another.
It still left me wondering if the WireView plugs would work with the Microscanner 2, that I've had for a while, but I'm pleased to say they work on that too!
So, I'm very happy  ;D.
I just have to ensue that I don't lose any more of the ID plugs, as I have done in the past!
I hope that information is helpful to others.
Post by: Andreychik on February 11, 2026, 10:42:34 am
Hello. I want to repeat this for my Fluke NetTool. Can I get a scan of the clean PCB, please?
Post by: ihartavi on September 20, 2026, 03:09:57 pm
Great topic, and thanks for taking the time to document all this. Much appreciated.
I came across this thread while looking for a compatible wiremapper for a first-gen Fluke NetTool.
Has anyone actually tried a wiremapper with the first-generation NetTool and had success? I’m particularly interested in the exact model/part number that works.
Also, if anyone has details on the compatible WireView/identifier part numbers, electrical specs, pinout, ID/resistor values, or any other compatibility information, I’d be very interested. Even info on third-party wiremappers that have been tested would be useful.
I’m trying to figure out what can actually be used with the older NetTool rather than just the later-generation units.
Thanks!
Post by: ihartavi on September 20, 2026, 03:24:38 pm
I just came across this eBay listing:
https://www.ebay.com/itm/125937097404 (https://www.ebay.com/itm/125937097404)
Any idea what’s inside this unit? Could it be identical to one of the units that has already been reverse-engineered in this topic?
Post by: ihartavi on October 03, 2026, 02:01:55 am
I believe I’ve worked out the logic behind how the ID numbers are determined. However, I need clarification on one point: the schematic shows 12 resistors, while the Excel sheet lists 15. Am I missing additional information? Could someone explain the discrepancy?
Post by: ihartavi on October 03, 2026, 03:02:09 am
Can someone verify these?
      ID7     ID8           ID9
R12   49.9K   90.9K   232.0K
R11   44.2K   78.7K   205.0K
R4   113.0K   200.0K   523.0K
R15   56.2K   100.0K   261.0K
