The thing about frequency references is that you can use anything you want (even the cheap stuff) providing it's calibrated before use. I have a 10 MHz reference oscillator that's built using quality components and double-ovened yet it still drifts one or two hertz a day so, before use, I calibrate it to DCF77 at 77,5 KHz
If the waveform drifts one cycle on the scope in one second then my error is 100 ppb
If the waveform drifts one cycle on the scope in ten seconds then my error is 10 ppb
If the waveform drifts one cycle on the scope in a hundred seconds then my error is 1 ppb, close enough, anything else is a bonus.
