Author Topic: Review on YiHua 878D  (Read 2396 times)
Offline madhu.wesly01Topic starter
  • Country: in
  • If you want to be happy, BE!
« on: May 09, 2019, 04:38:35 pm »
I am planning to buy YiHua 878D 2 in 1 soldering rework station. Previously, I have used Hakko's FX-888D soldeing station and YiHua 858D rework station. This time I want to take an integrated one(multi-function) like 878D. Please let me get your review/comments on this product. Will it perform at-least parallel(or comparable) to the FX-888D & 858D?
TIA.
Regards,
Offline OM222O
Re: Review on YiHua 878D
« Reply #1 on: May 09, 2019, 04:46:26 pm »
I bought the 862D+ off of amazon. it's been pretty decent so far, but the supplied conical tip with the iron is garbage and dies quickly. I also had the magnetic switch in the hot air gun break but after replacing it with a high quality one everything has been buttery smooth. the main advantage is it's so cheap, you can't beat it in terms of value.
The following users thanked this post: madhu.wesly01
  • Country: in
« Reply #2 on: May 10, 2019, 04:57:03 am »
Any suggestions/comments on YiHua 878D..?
Regards,
Offline OM222O
« Reply #3 on: May 10, 2019, 05:24:57 am »
all yihua products are basically the same, with some marginal differences in the feature set which you can find on their website. what I said about the 862D+ holds true for the 878D as well. just check the feature set before you buy (862D+ is a better version and not that much more expensive than the 878D).
