I was recently using a lightsaber (high powered torch) for about 10 minutes, when it suddenly shut off. This had happened before and I just had to charge the protected 18650 Li-Ion battery back to full.
This time however, my charger did not charge the battery. Instead, after 18 seconds the charger displayed "FAIL". My initial thought was that the cell was under its discharge voltage or the chargers minimum charge voltage, it was at 3.2V. However, after manually charging the cell to 3.5 volts, the charger still gave the same response. By manual charging I mean hooking the battery up in parallel with another 4.2V battery (at 4.0V). This got it to 3.5V yet the charger did not begin charging. That does point to the charger. When I put it in the charger, the cell momentarily charged to 3.7V. This is probably just the output of the charger.
The cell still functioned, but with limited voltage. It's voltage when charging went to a maximum of 3.7V but no further.
The product page says "Fully protected against over-charge, over-discharge, short-circuit, and over-current". It does not mention under-voltage, but 3.2V is hardly under voltage. Is this correct?
The product page also states that the recharging voltage is 3.7V. I assume that this means the voltage for the cell to begin charging. Does this also mean that it should not drop below 3.7V?
Interesting to note: Not long ago I gave myself a shock, which felt like an oscillating voltage from the negative terminal of the charger. I measured the current through me and it was 1-2mA. The chargers AC adapter doesn't have a ground pin and I was not isolated from ground.
Any thoughts and ideas on what went wrong here?
