Just looking for some information, if anyone has any idea what is going on with a linear 12 Volt power supply. I'm using a high current linear power supply to run a 100 watt linear amplifier. But when I key the microphone it's stopping the two cooling fans, if I let the key go, the cooling fans come back to life. I've checked for voltage drop, there isn't any that would stop the cooling fans. If I try a different load (halogen lamps) The fans stay on and run fine. Do you think this could be an RF thing, where the linear amplifier is near the power supplys cooling fans. Is it possible for stray RF energy to interfere with the axial fans functioning ? I'm really at a loss to why the cooling fans stop on transmitting on a HF transceiver and linear amplifier. Thanks for reading, any thoughts appreciated.
