Author Topic: RF stripboard techniques.  (Read 7053 times)
Offline djsbTopic starter
« on: March 06, 2010, 01:14:11 pm »
Does anyone have any special techniques for building RF circuits on stripboard? I need to build a VCO that runs at approx 10MHz. The circuit uses 3 transistors, 1 coil and a varicap/varactor diode as well as other supporting components.
I need to minimise long wireing and utilise some kind of ground plane if possible.
I saw a technique on Dave's video's but can't remember the specifics apart from it being called dead bug or something.
I will mainly be using through hole components as this is a proof of concept test build/prototype.
Anyone have any tips or methods specific to RF.
Thanks.
David.
London,UK
« Last Edit: March 06, 2010, 01:17:58 pm by djsb »
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Re: RF stripboard techniques.
« Reply #1 on: March 06, 2010, 01:42:31 pm »
In answer to my own question I found this link.
http://www.piclist.com/techref/pcb/manhattan.htm
and this
http://www.aoc.nrao.edu/~pharden/hobby/Hobby.shtml
Any thoughts?
David.
« Last Edit: March 06, 2010, 03:12:05 pm by djsb »
Hertfordshire, UK
Offline joelby
« Reply #2 on: March 07, 2010, 12:46:59 pm »
Dead bug is easy to do with through-hole components. Get some blank (copper-clad) PCB, glue ICs upside down (with their legs in the air), and solder things together directly. The PCB acts as a large ground plane and this works quite well for RF.
The Manhattan technique in the links you provided looks very tidy but also like a heck of a lot of work! Making a PCB really does not take very long, allows you to very easily use SMT components, which may be important if you're using ICs that don't come in DIP packages, makes a design completely repeatable, and looks a lot more professional. I admire people who build everything using these methods, but it's slow and fiddly.
Offline jimmc
« Reply #3 on: March 07, 2010, 01:01:07 pm »
If you really want to use something like stripboard then there are boards with a colander ground plane on one side and either strips or pads on the other.
See http://www.verodirect.com/images/PDF/Veroboard%20Board%203.pdf
Pricey but works well at RF, especially the pad version when used with 0805 SMD components.
Jim
