Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
RF switch IC selection
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: RF switch IC selection (Read 3685 times)
Asim
Regular Contributor
on:
August 25, 2015, 03:39:17 pm »
Hello everyone,
I am working on a project where an NFC reader with multiple antennas is needed ( each antenna will be installed in a different place) . I am planning to use the NFC reader from Adafruit PN532
http://www.adafruit.com/datasheets/pn532ds.pdf
For the RF switch, I am thinking of using HMC252QS24
https://www.hittite.com/content/documents/data_sheet/hmc252qs24.pdf
I came across it while searching through digikey. it's package size makes it easy to solder by hand.
My question is: Is it a good selection? any reason this wouldn't work ?
Regards,
Asim
Logged
KJDS
Super Contributor
Country:
Re: RF switch IC selection
Reply #1 on:
August 25, 2015, 04:02:00 pm »
How much isolation do you need and how much insertion loss can you tolerate?
Logged
http://www.ebay.co.uk/sch/kjds_stuff/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
rvalente
Frequent Contributor
Country:
Reply #2 on:
August 25, 2015, 04:34:27 pm »
RF is totally not my field, but I have used minicircuits in the past (for a impedance converter for AM/FM automatic testing for car radios)
http://www.minicircuits.com/products/Switches.shtml
Logged
Neganur
Supporter
Country:
Reply #3 on:
August 25, 2015, 07:08:20 pm »
HMC252QS24 is so expensive for a single one (~15 EUR), I'd suggest looking for "SP6T" on ebay.
You'll easily find something like
eBay auction: #281765034520
. Unless of course, it has to be small and not second hand.
Your NFC reader is at some 13 MHz so there might be some other solution available. Mind the cable loss. NFC is not a lot of power and not really meant for long passive transmission.
Logged
Kleinstein
Super Contributor
Country:
Reply #4 on:
August 25, 2015, 07:09:44 pm »
I am not shure the output of the chips have a well defined impedance. So it might allready be difficult to only have a long cable between the chip and the antenna. Adding a switch might add significant damping to both sending and recieving.
The frequency is not that high - so I don't think special HF switches are needed. Also isolation is likely less critical than on resistance.
Logged
nctnico
Super Contributor
Country:
Reply #5 on:
August 25, 2015, 08:28:57 pm »
At 13MHz you can use about any CMOS switch. A 74HC4016 for example has a bandwidth of 150MHz (NXP). There are also analog muxes out there.
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #6 on:
August 25, 2015, 10:58:48 pm »
Yeah, just go with regular CMOS...
74HC might be a little weak in the poop for a power signal (you'll lose 3dB easy from switch resistance), but any of the DG403 or similar analog switches will do the job no problem.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Asim
Regular Contributor
Reply #7 on:
August 26, 2015, 03:39:53 am »
Thanks guys,
Using a regular cmos device would be cheaper and easier to find.
Tim, the GD403 is SPST, I am looking for sp4t or sp6t . Any suggestions for a high power analog switch. I will keep looking
Logged
LukeW
Reply #8 on:
August 26, 2015, 03:59:31 am »
Note that the PN532 antenna port is balanced, so you'll need a balanced switch, it's not single-ended RF to the antenna.
Logged
nctnico
Super Contributor
Country:
Reply #9 on:
August 27, 2015, 06:50:52 pm »
Perhaps an easier way is to buffer the antenna TX signals with a differential output opamp (maybe with enable) and use an analog multiplexer to select between the various receiver signals. OTOH using multiple RFID chips and multiplex them at the MCU side could be a cheaper solution.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
