Hey all, over the last few months I've been working on an RGB LED light for scanning film with a DSLR. The basic idea is that I'm trying to mimic the approach used by high-end film scanners, which use red, green and blue light of specific wavelengths to measure the density of the individual film layers. The requirements for the light source are:
• Specific wavelengths of light, specifically 460nm blue and 660nm red which means I can't use combined RGB LED modules
• PWM dimming, because altering the driving current would change the emitted color wavelength
• 10-bit PWM, because I want fine adjustment of the colors relative to each other
• high frequency PWM to prevent flickering at high shutter speeds
• 24V input for ease of designing/source a power supply
I'm currently designing the board that will contain the driver circuits, and I had a few questions I'm hoping someone here can help me out with. I've chosen to drive my light with 3x TI TPS92515, which are designed for high frequency PWM via shunt-FET dimming. I've taken apart and analyzed several lights designed for photography and video, and they seem to all target 30khz as a PWM frequency, so I've decided to shoot for that frequency as well. It's well above the fastest shutter speed, and also above the frequencies that would emit an audible whine from the PWM circuitry.
I've chosen FDD6296 as my shunt FET (the LED current will be shunted through the FET during the "off" periods) because it features a combined on/off time that is less than the minimim pulse width for 10-bit, 30khz PWM.
The PWM signals will come from an ESP32 that will also function as the MCU for user interaction. I've chosen an ESP32 because I've read that I can use the WiFi and Bluetooth features without requring additional FCC certification as an intentional emitter, so if I decide to make a commercial product down the line I would only have to worry about the driver and PWM signals.
The LEDs I'm using will be from the Luxeon 2836 color line. I plan to run them at a maximum of 120mV, with 8 in series. The highest voltage LEDs have a voltage drop of ~3V, so they should draw near the target amperage at 24V. I will be running 3 parallel rows of each color, so each color will draw 360mA total. The overall power requirements for the light should be 1.08A at 24V = ~26W.
I'm particularly concerned about thermal issues on my driver board, so I've tried to give the components that will be subject to higher current some copper pour and thermal vias to dissipate heat. I've focussed on the inductors, shunt-FETs, driver chip and input filter circuitry.
I've based my board on a few reference designs that TI offers for this driver, though I've had to make modifications for the shunt-FET and to fit three drivers on the board. Some of the concerns I have with my design:
• VIN pin traces are on the thin side. On the reference board, there is a pour for the VIN area, but the actual connection to the VIN pin is still rather thin. As I understand it, the function of the VIN pin is to draw power for the chip and to feed the high side of a comparator that determine the output current. The datasheet notes:
"The device does not internally limit the maximum attainable average LED current. It does have a thermal limit based on the maximum junction temperature. The maximum junction temperature is a function of the system operating points (efficiency, ambient temperature, thermal management), component choices, and switching frequency."
So I'm not sure I actually need a thick trace to feed that pin.
• PWM traces are long. I was hoping to have all of my inputs on one side of the board, but my layout results in the PWM traves running the length of the board. I'm wondering if there's a reason to keep them short.
• My output voltage is equal to my input voltage in some cases. I'm trying to run the green LEDs at 120mA and 24V from a 24V power supply. I assume that I'll lose some voltage, and they'll actually end up running at a lower current/voltage. I'm not sure that's a problem, as long as the color wavelength doesn't shift too much.
• I'm using a single set of current comparison resistors (R5 & R6) for all three drivers. I figured I could get away with this since each color will be driven at the same current, but some of the drivers are further away from the resistors than others, and the datasheet does note that long traces can alter the resistance of the comparator circuit, and therefor the output current. I'm hoping the difference won't be significant.
• A friend of mine, who is fairly knowledgeable but not really an electrical engineer, suggested my entire approach was flawed and I should drive the LEDs with constant voltage instead of constant current since I'm using a power supply that already provides a regulated 24V. Every device I've analyzed has used a constant current driver, but I'm open to a constant voltage design since it would be significantly simpler.
I'd love to hear whatever feedback anyone might have regarding my design!
Schematic for the board (please ignore the component values for now, they are placeholders):
http://ur.sine.com/temp/driver/schematic.pdfSchematic for the LED grid, for reference:
http://ur.sine.com/temp/driver/led-grid-schematic.pdfTop side of the board:
http://ur.sine.com/temp/driver/board-top.pdfTop side of the board with pours filled:
http://ur.sine.com/temp/driver/board-top-filled.pdfBottom of the board:
http://ur.sine.com/temp/driver/board-bottom.pdfBottom side of the board with pours filled:
http://ur.sine.com/temp/driver/board-bottom-filled.pdfAll layers:
http://ur.sine.com/temp/driver/board-all-layers.pdfReference designs:
https://www.ti.com/lit/ug/slvuar5/slvuar5.pdf?&ts=1589589788530 and
https://www.ti.com/lit/ug/tiducq5/tiducq5.pdf?&ts=1589589866368For the curious, an article I wrote about DSLR scanning with tri-color compositing:
https://medium.com/@alexi.maschas/color-negative-film-color-spaces-786e1d9903a4A more technical article about densitometric scanning:
http://mjbcolor.com/ScanningMetric.pdf
