Author Topic: Right angle rgb leds in smd  (Read 7726 times)
exapod
  • Guest
« on: November 15, 2013, 10:10:59 pm »
For a product i'm designing i need some medium power rgb led but the problem is that the direction of the light must be perpendicular from the board (sorry for the bad english..).
I only found this http://www.kingbrightusa.com/product.asp?catalog_name=LED&product_id=APFA3010SEEZGQBDC but is not very powerful and the price is a little too high.
I don't have experience in large quantity pcb manufacture and i would like to know if assembling the board (all smd part and on one side) with the smd led (expensive) is still cheaper than using a normal trough hole led (cheap) that someone should bend and solder.
Thanks for the help.
Offline gotvolts
  • Got Volts?
    • Home of the most exciting kits on the planet!
Re: Right angle rgb leds in smd
« Reply #1 on: November 15, 2013, 10:59:24 pm »
Physically bending and forming a lead on an LED is labor and that will cost you considerably (relatively speaking) - even if it didn't require custom bending, the fact it is thru-hole is another process and will add to assembly costs.
There are actually a lot of right angle LEDs both SMT and TH.  Are you looking for a color LED for indicator purposes?
High Voltage and Tesla Coil Kits, Audio Modulation, LED and Lighting Kits, and more!!!
http://www.easternvoltageresearch.com
Plasmasonic Solid State Commercial Tesla Coil
Online David_AVD
« Reply #2 on: November 16, 2013, 03:01:58 am »
I saw some nice Everlight ones in a demo kit the other week.
Offline notsob
« Reply #3 on: November 16, 2013, 03:08:45 am »
exapod
  • Guest
« Reply #4 on: November 17, 2013, 07:24:39 pm »
Can you point me some right angle rgb leds in smt? The ideal luminosity is more or less 1000 mcd.
Online David_AVD
« Reply #5 on: November 17, 2013, 08:44:02 pm »
Have you done a parametric search on Mouser or Digikey yet?
Offline tsmith35
« Reply #6 on: November 18, 2013, 04:53:20 am »
If it's a chip LED, perhaps you could stand it on its side to solder in place.
Online David_AVD
« Reply #7 on: November 18, 2013, 06:02:28 am »
There are plenty of side-view SMD LEDs available.  Not so many in RGB, but they exist per my first post above.
Offline ddavidebor
    • Smartbox AT
« Reply #8 on: November 18, 2013, 06:17:19 am »
Why don't you solder on the surface of your board a tht led, without bending the pins, just cut them. You might need to cut a free space for the led on the board.
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
Offline Codemonkey
« Reply #9 on: November 18, 2013, 07:14:43 am »
Did you even bother to read the bit where he says high volume ? How exactly is the pick and place machine going to a) pick up a through hole component, and b) cut its legs off and place it on a board on its side  |O
exapod
  • Guest
« Reply #10 on: November 18, 2013, 10:46:30 am »
Yes, i only found the one that i posted, i think that i will use two of them.
Offline ddavidebor
    • Smartbox AT
« Reply #11 on: November 19, 2013, 04:25:47 pm »
Okokokokokokokokokokokokiokokokok
Offline mariush
« Reply #12 on: November 19, 2013, 06:36:11 pm »
Have you considered using light pipes?
http://www.digikey.com/product-search/en/optoelectronics/optics-leds-light-pipes/524541
They may not be easy to install with an automated process but you may be able to source some "snap-in" type, or press fit.. so you wouldn't have to solder anything and it wouldn't add a lot of time to assembly.
it costs a bit of money, but on the other hand you'd use some more common rgb leds, less expensive, easier to source etc....
