Hi all,
I'm using a TI TPS386000 integrated supervisor / watchdog part in a design I'm working on at the moment, which is great for sequencing the rails at power on, i.e. power is applied, once it is within an acceptable window, a switching regulator is enabled, once the output of that is above a certain threshold a downstream LDO gets enabled and so on, all with a programmable delay to avoid large inrush currents, which is all well and good.
My confusion is during regular operation if, for example, the output of the switching regulator goes out of bounds, I would like to cycle the enable pin of that regulator itself. But I can't just use a regular voltage supervisor to achieve that, because when you first apply power, the regulator output voltage will be below the acceptable threshold, thus the enable input will be held low by the supervisor and the regulator will never be enabled in the first place.
I've been trying to come up with some convoluted analogue delay circuits to achieve what I want, but it feels as though it's all getting a bit messy and needlessly complicated. Am I missing something simple here? Is there a standard way of achieving this behavior, or am I barking up the wrong tree completely?
Any thoughts would be appreciated,
George
