Author Topic: Knobs for these Potentiameters?  (Read 2542 times)
Offline skylerTopic starter
« on: September 13, 2015, 03:53:33 pm »
« Last Edit: September 13, 2015, 03:59:46 pm by skyler »
Re: Knobs for these Potentiameters?
« Reply #1 on: September 13, 2015, 04:08:26 pm »
Pretty much yes, the shaft is 1/4inch diameter, or 6mm.
Offline Jidis
« Reply #2 on: September 13, 2015, 05:54:36 pm »
But are those still equivalent for a knurled "press-on" knob? I've had ones where you had to pound them on, bending the shaft's prongs, which I guess was a 6mm trying to go on a quarter inch shaft.
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
« Reply #3 on: September 13, 2015, 05:58:27 pm »
Anything but chicken head knobs!
Voltage does not flow, nor does voltage go.
« Reply #4 on: September 13, 2015, 06:10:11 pm »
Fluted shaft is typically 6mm, though there are some 5mm and 4mm, but the back is always different to the ones on eBay. Those are always 6mm. old ones from 1960 will be non fluted and 1/4inch, fixed with a set screw or a collet.
Offline dom0
« Reply #5 on: September 13, 2015, 06:31:46 pm »
Eh, a 6 mm knob won't fit on a 1/4 in (=6.35 mm) axle. Okay, the other way around it does (but it wobbles), and only if it has a fixing screw (not push on or collet).
« Reply #6 on: September 13, 2015, 06:37:46 pm »
Chinese 1/4 is 6mm, they round diameters down to cut cost.
