Author Topic: Surv. camera setup with pi? help!  (Read 1336 times)
Offline MyHeadHzTopic starter
« on: February 21, 2017, 10:11:31 am »
So I just found out that someone has been trespassing and vandalizing my property.  I need a surveillance camera...
I have raspberry pi's, a good quality webcam, and SD cards/HDD's to spare.  I need to set it up ASAP.
It doesn't have to be super technical or efficient.  I will be able to plug everything in to a wall.  It can simply record the entire time in HD, and log it to the drive via USB.
I have never done anything like this, so I'm a complete noob. :o  Any resources for setting it up?
Offline Delta
Offline bobaruni
Re: Surv. camera setup with pi? help!
« Reply #2 on: February 21, 2017, 12:48:00 pm »
Just stick this image an SD card and plug it into your PI and a suitable wifi dongle and webcam, it couldn't be simpler and works a treat, has a built in web server and record, motion sensing etc.
https://github.com/ccrisan/motioneyeos/wiki
« Last Edit: February 21, 2017, 12:50:48 pm by bobaruni »
« Reply #3 on: March 09, 2017, 03:15:06 am »
Thanks!  I decided to do with your MotionEye OS suggestion.  It was simple to set up, and I am impressed so far.
I've now had it set up for a while.  I set it to do videos, though it was set up for images while I was testing.  It may be trying to do images and video... nothing interesting on the images.  the motion sensitivity may be too high.
The images seem to be fine, but all the videos are either 0 byte files, or corrupt/unplayable.  any suggestions?  It also seems to drop off the wifi (built-in Pi3 wifi module) a lot.
My two thoughts so far are 1. perhaps using the camera, pi, wifi, and writing to memory card uses more power than my power supply can put out (700 ma at .5 volt, under recommended 1 amp).  2.  Perhaps my memory card is too slow, causing aborted/failed writes.  Any other suggestions would be greatly appreciated.
I will try running the setup directly from a battery (so pure DC, little/no noise) which can output up to 3 amps at 5v for at least a few hours.  That should rule out (or confirm) any power supply issues.  I will update with results.
« Last Edit: March 09, 2017, 03:17:32 am by MyHeadHz »
