Author Topic: Robust DC brushed Motor Driver  (Read 532 times)
Offline ali_asadzadehTopic starter
« on: June 17, 2020, 11:46:09 am »
I want to design a 5-10A , 36-52V DC brushed motor driver, and I know that there are tons of stuff out there, But I want to know who has done it better,and get some Ideas, Do we have some cool open source project for that, like the ODrive for Brush-less versions ;)
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline max_torque
    • bitdynamics
Re: Robust DC brushed Motor Driver
« Reply #1 on: June 17, 2020, 07:10:25 pm »
make you life easy and use two high current smart half bridges, ie something like
https://www.infineon.com/cms/en/product/power/motor-control-ics/brushed-dc-motor-driver-ics/single-half-bridge-ics/btn8982ta/
won't get you up to your 52v, but will save a lot of hassle and be very robust (ime, you can dead short those ICs with a screwdriver across their output pins at fully current and they survive....)
If you want to go to a descrete's solution then it's a LOT more work with mosfets and drivers etc and you'll have to provide all the necessary safety (overcurrent, shortcircuit, de-sat detection etc) yourself
The following users thanked this post: ali_asadzadeh, james_s
« Reply #2 on: June 18, 2020, 05:56:13 am »
Thanks for the feedback, I'm interested in reading the motor Current too, this device does not provide this feature, also it seems that it has a supply voltage of up to 40V only
